#1 & 4 pistons not hitting TDC simultaneously???
  • APE Jay
  • APE Jay's Avatar
Re: #1 & 4 pistons not hitting TDC simultaneously???
25 Feb 2006 13:33
#26381
Our welding price is only for welding. We have long ground rods that we insert thru all of the wrist pin holes to see if it is twisted. If the rod will go thru all four, then we weld it. If not, we send the customer to Gardner. He is the best with the roller bearing cranks.
Try 207-664-0377 or 866-664-0401
Jay
Post edited by: APE Jay, at: 2006/02/25 16:33
  • no name
  • no name's Avatar
25 Feb 2006 13:42
#26386
@Jeff.Saunders
absolutely correct,many J-motors had these problems.
In Germany we have no speed limits on (many) highways
and in the 80`s our Kawasaki dealers had one of these (high RPM killed) motors every month.
Don't drive with this crank otherwise you will need a new cyl. head,pistons ...
  • Snakebyte
  • Snakebyte's Avatar
27 Feb 2006 02:08
#26722
I believe any crank that is pressed together will "twist" under load. Here is a thought what if #4 is the one that IS correct??? I would get it indexed then welded. Sorry to here the situation. Thing do disappear when you move Good luck man.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
27 Feb 2006 05:53
#26736
Maverick:
Good advice here, but I'm curious on what prompted you to disassemble your motor in the first place? Was this a general rebuild, were you having trouble with the motor, was this a recently acquired bike that you didn't know history of? Was the bike running before the teardown? Thanks.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • wiredgeorge
  • wiredgeorge's Avatar
27 Feb 2006 06:41
#26741
I had a machinst friend acquire a 17mm blank drill bit rod which is VERY VERY precise. I use it as APE Jay describes. Before rebuilding ANY engine, I insert the rod THROUGH the piston pin holes in the connecting rods. The rod CAN NOT go through if the crank isn't true as the rod fits as tightly as the piston pins themselves. It is a cheap and very effective way to check if a crank is straight. If I owned this J engine in question where the crank is definitely twisted, I would NOT run the engine as is and would split the cases and pitch this crank and buy another from eBay OR get this one fixed. I suspect that an eBay crank would be cheaper. If these cranks have a tendency to twist, I would consider sending it to a company like APE to weld. Truing the crank will be fairly expensive but that is, of course, a very viable option as you may not be able to find a crank readily on eBay and may not be willing to wait for one to come up on auction.
  • steell
  • steell's Avatar
27 Feb 2006 07:11
#26749
If anyone is wondering where to get the drill rod, it's available at MSC for ~$17 plus shipping. Order a catalog while you are there, it's hardbound, huge, weighs 7-10 pounds (seems like it anyway), they ship it UPS, and it's free :laugh: :laugh:
  • Maverick
  • Maverick's Avatar Topic Author
27 Feb 2006 11:28
#26795
Hi Michael,
Interesting you should ask. I had a red-line 'incident' on my first ride on the bike just before Thanksgiving '05. The throttle stuck open on me. In my panic, I clutched before I hit the kill switch resulting in severe red-line. It never ran the same since. So I tested my compression. All cylinders were low, but #1 was nearly 25% lower than the others. Ran a wet compression test and resulting pressures went way up - nearly doubling on #1. So diagnosed bad rings. Ran a leak-down compression test on the other cylinders which indicated leaking valves. So I tore the top-end off, lapped the valves, installed new rings, and was in the process of buttoning things back up when I noticed the twist.
So to answer your question, it was a new bike to me, didn't know the history (not even mileage b/c the speedometer/odometer was missing), plus had performance issues after the red-line incident. From what I understand, high revs are usually what causes the crank to twist.
So the real question is: "Why in the world did Kawasaki put a press-fit part in such a high torque application?"
Maverick...
1981 KZ1000M1
  • wiredgeorge
27 Feb 2006 11:33
#26797
Ask anyone who ever owned a 1982 GS1100 and missed a shift when running hard... the answer back them used to be a joke which was to send all the Falicon kids to college bwhahahaha
This isn't unusual for an early 80s bike. I have bent several crank shafts and the reason was missing a shift and running the engine way past redline. There were lots of bikes out there where this never became a problem but the very nature of owning a KZ1000 or GS1100 usually meant that the owner liked to ride hard I guess.. Good luck and keep your eyes on eBay!
  • wireman
  • wireman's Avatar
27 Feb 2006 11:56
#26808
1982 gs1100e suzuki it was silver with black yosh pipe spring of 90 broke the crank!was running like a bitch uptill that point!!!!!!!!!!:whistle: :whistle: goodluck,happy wrenching!
  • APE Jay
  • APE Jay's Avatar
27 Feb 2006 14:40
#26842
There you go. You can even check a crank while it is still in the cases.
Jay
  • RomSpaceKnight
  • RomSpaceKnight's Avatar
27 Feb 2006 14:50
#26843
Was the issue with Suzuki Gs's the helical cut gear off the crank? Did this not go away after the factory switched to a straight cut gear? At least with a pressed together crank there is the possibility of getting it repaired and trued.
  • APE Jay
  • APE Jay's Avatar
27 Feb 2006 22:11
#26980
No... The helical gear would cause the clutch gear to get pulled in and hit the crank cheek.. They will still twist with a straight gear if the crank is not welded.
This is why we put the heavy duty backing plates on the Zuk basket assembly to make it stiff enough that it resist being pulled into the crank cheek.
Jay
