- Thank you received: 1
odd plugs ??
- gane
08 Feb 2009 18:55 #263087
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic odd plugs ??
Something to chk. B8ES plugs usually come w/alum.top-hats screwed onto plug's core.resistor caps(phenolic/ceramic's) usually attach to threaded core. and make a satisfying racheting feel when fit. G
- triggerbilly
08 Feb 2009 19:11 #263096
by triggerbilly
1982 kz750-e3
1983 cb1000c
plano. TX
Replied by triggerbilly on topic odd plugs ??
I've got a full set of B8ES in now and it's running fine a few little pops out of the right hand side exhaust (that's another post that'll be coming soon though !!)(unless you have any ideas ?)
I'm gonna check pout all the caps and wires tomorrow
compression and valve clearances kinda freak me out
I'm thinking it's a little too technical for me (and i don't wanna find anything really messed up inside the engine !!)
1982 kz750-e3
1983 cb1000c
plano. TX
- Thank you received: 2829
08 Feb 2009 19:18 #263101
by 650ed
Replied by 650ed on topic odd plugs ??
Do you have a Kawasaki Factory Service Manual for your bike? If you do, checking the valve clearances will be fairly easy. If you don't have the FSM, you really should get one as it makes life easy and helps you avoid making simple but costly mistakes. Ed
