- Thank you received: 6
Cylinder Plugs
- grumpy56
07 Feb 2009 14:36 #262757
by grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
Cylinder Plugs was created by grumpy56
Hello. I ordered 4 plugs for my KZ1000 and I don't think they are the right ones. The P/N in the Kawasaki parts diagram is 92066-1106 and it appears that this was superseded by 92066-1552 (the parts I received). The plugs on my bike are black rubber (at least on the outside - haven't taken off the valve cover yet) with what seems to be 3 distinct surfaces (on the outside). The plugs I received have a metal (aluminum face) on one side and they are a half circle. Would like some info from you guys before I go back to the dealer. Thank you.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- MFolks
- Thank you received: 540
07 Feb 2009 15:22 #262758
by MFolks
Replied by MFolks on topic Cylinder Plugs
The cam plugs(the part that covers up the camshaft opening)is available in either the black rubber or like the ones you have. Make sure there is hole for the valve cover bolts to go through(one on each cam plug).
- grumpy56
07 Feb 2009 17:06 #262778
by grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
Replied by grumpy56 on topic Cylinder Plugs
Thanks Mike. Yes, they do have a through hole and I guess it doesn't matter that they have the aluminum bonded to them.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- APE Jay
- Banned
- Thank you received: 58
