Compression Ratio vs. Grade of Gasoline
- Spot
Good judgment comes from experience, which usually comes from bad judgment. - Will Rogers
- BSKZ650
- Thank you received: 14
What are you wanting to build would be the first question?
77 ltd1000, current rider
76 kz900, just waiting
- mark1122
- Keep twisting it
- Thank you received: 109
12:1 is only acceptable on a new bike with a down draft,4 valve, water cooled head.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- bountyhunter
- Thank you received: 337
- BSKZ650
bountyhunter wrote:
There is an actual octane booster (with lead) still available that can boost octane anywhere from two to six points if you are set on building a screamer. It's called Octane Supreme 130. The stuff available in auto stores will only raise the octane about 1/2 point.
- PLUMMEN
- Thank you received: 104
- TeK9iNe
- What did you do!?!
- Thank you received: 28
I say do whatever you want to your bike . Someone will usually have an idea of what octane is necessary for whatever mod.
You can start at a suggested octane level, then slowly go down ratings till you start to get knock under hard/uphill accel. then just stick one level above that.
I know a few guys that have had success with this method.
Cheers.
:blink:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- bountyhunter
Dont use this CRAP, it dosent mix even with the gas, I know first had what will happen, its called a hole in the piston!!!
bountyhunter wrote:There is an actual octane booster (with lead) still available that can boost octane anywhere from two to six points if you are set on building a screamer. It's called Octane Supreme 130. The stuff available in auto stores will only raise the octane about 1/2 point.
It mixes with my gas. never had a problem, been using it two years.
These guys also recommend it:
www.nowearracing.com/
www.wildbillscorvette.com/prod01.htm
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
What is your wildest dream for this motor? This is always the easiest question to answer.
What are you really going to use it for? This question is harder.
What do you rate your skill level at, as a rider and a mechanic? Everyone started at the bottom and worked there way up from there. If you have skills then shoot for the moon.If you are new to riding or engine building, keep it simple and give yourself a chance to develp some skills.
There are some good running low compression bikes out there. There isn't anything wrong with a good stock piston 1015cc with some drop in cams, header, carbs., gearing & ignition. It's always a good starting point and a motor that you can hammer-on! It will perform better with a 900 crankshaft in it. It will give you a chance to do it on a budget.
Everyone here will be more than willing, to help you out!
Myself, I would be willing to share with you the specs. of a low compression 1015cc I have built many times.
- Spot
To answer kzz1p:
My dream for this bike is to plagiarize jordan's engine work and add the 6-speed tranny and oil cooler from the KZ550 donor engine sitting in my garage.
It's my daily driver in lunatic Hampton Roads, VA (when it's running) and I am planning trips to Texas, Oklahoma and Oregon.
I've been riding off and on for 32 years, but have only moderate mechanic experience (carbs, brakes, sprockets, etc). I'm looking for a local mechanic (dealers won't touch it), but will try it myself if I can't find one.
I used to prefer Yamahas, but since I bought my Kaw and found this website, it's personal. You guys rock!
- kzz1p
Me, I, Myself! If I was going to modifiy that motor. I would use the 10.25:1 compression pistons. I would use a cam that has the same intake, opening & closing points as stock or as close as I could get. Yes, a later intake closing would be better but the cam might be very big for your daily driver.
- Spot
