Camshaft chain tensioner bolt
  • restless
  • restless's Avatar Topic Author
24 Feb 2006 18:00
#26205
Hello kz riders, I'm trying to finish up a valve job on a '80 kz750e and I can't find the original lock bolt can any one tell me how long a bolt I need to replace it?
  • RetroRiceRocketRider
  • RetroRiceRocketRider's Avatar
  • ...bring in the machine that goes PING!
Re: Camshaft chain tensioner bolt
24 Feb 2006 18:12
#26209
Welcome to KZr restless.
I believe that bolt is a 6x22, but I could be wrong.
The Kawasaki.com site doesn't list the true bolt size.
My suggestion would be to start with perhaps a 6x25 bolt, and then add a nut (or maybe 2?) to lock the bolt in place once you've set the proper tension.
Post edited by: RetroRiceRocketRider, at: 2006/02/24 21:13
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
  • wireman
  • wireman's Avatar
24 Feb 2006 18:13
#26210
any idea what size the bolt is?
  • JR
  • JR's Avatar
24 Feb 2006 19:22
#26231
Is it this the bolt......the one sticking up ? In the cam chain tensioner.
I took it out and measured it at 6 x 30mm so anything thereabouts or a tad longer should work.
Woodstock ON Canada
1980 kz750E1, 4->1, K&N pods
  • wiredgeorge
  • wiredgeorge's Avatar
27 Feb 2006 07:08
#26747
Doesn't really matter how long the bolt is as long as it can catch the shaft inside and have enough room on the outside where you can install a locknut.
The bolt itself is 6mm with 1.0 pitch thread... very standard size and the same pitch as most all other 6mm bolts on any Kawasaki.
