Reversed Heads
  • Gomer
  • Gomer's Avatar Topic Author
  • I crap worms that look like spaghetti
Re: Reversed Heads
08 Feb 2009 14:34 - 08 Feb 2009 14:36
#262985
What KruZer is saying is the ram effect won't have much effect on a KZ because the aerodynamics spoil the airflow around where the carbs would sit if the heads are reversed. Not that ram air doesn't do anything. To get the full effect I'd have to move the carbs off the heads.
flht1997 wrote:
what year XS are we talking?, all the ones i have had my hands in had multi-piece
Oops. My bad: The one I saw was an 81 and the cam was what was solid and the guy still cut, rotated and rewelded. He made a degreeing plate out of an old CD.
Last edit: 08 Feb 2009 14:36 by Gomer.
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
Re: Reversed Heads
28 Nov 2009 11:11
#336287
Looks like Yamaha is producing a factory motorcycle with a reversed cylinder head - could be the start of a new trend??
2010 YZ450F:
The Kaw List:
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: Reversed Heads
28 Nov 2009 14:12
#336311
2010 YZ450F: [img size=600]
Very coolB)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • Old Man Rock
  • Old Man Rock's Avatar
Re: Reversed Heads
28 Nov 2009 18:06
#336354
Well you'd have to change the crank, gearing and output drive rotations or some Plummen type rigging... :P
Whoa, front nose wheelies... Ewwwwwwwww, someone start a posting!
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Reversed Heads
28 Nov 2009 18:33 - 28 Nov 2009 18:45
#336365
how about just disconect the rear drive chain on a rokon :laugh:
Last edit: 28 Nov 2009 18:45 by PLUMMEN.
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: Reversed Heads
28 Nov 2009 22:58
#336406
LOL :laugh: Sweet!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • APE Jay
  • APE Jay's Avatar
Re: Reversed Heads
29 Nov 2009 17:34
#336611
Ram air on modern sportbikes works because it goes into an airbox. If the carbs were in front, you would have to have an airbox up front to make it work. A lot of work was done with this in a wind tunnel.
As for the fuelers, Elmer told me himself there was no advantage other than maintenance. When they first did it, they were using positive displacement blowers. Only so much air moves from one side of the blower to the other side with each revolution, regardless of how much you try to ran thru it.
  • Gomer
Re: Reversed Heads
29 Nov 2009 21:51
#336651
Like I said before. I don't care about the ram effect or ease of maintenance. I just think it's the tits.
  • TexasKZ
  • TexasKZ's Avatar
Re: Reversed Heads
29 Nov 2009 22:12
#336653
Seems like a perfectly good reason to give it a try.
  • TerryK
  • TerryK's Avatar
Re: Reversed Heads
07 Dec 2009 13:33
#337953
2010 YZ450F:
That was done for mass centralization.......and marketing. ;)
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
  • Becker
  • Becker's Avatar
  • The Doctor Will Rise Again
Re: Reversed Heads
07 Dec 2009 13:58
#337958
It was also done to give the intake a straighter shot into the combustion chamber.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
  • TerryK
  • TerryK's Avatar
Re: Reversed Heads
07 Dec 2009 14:00
#337959
There are many inherent advantages to the design. I was only pointing out the main reason Yamaha went with this design.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
