ape cam cover caps
- Buda
03 Feb 2009 00:44 - 03 Feb 2009 23:56 #261861
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
ape cam cover caps was created by Buda
Will the ape cam cover caps seal the smog stuff or do I need to plug the holes in the cam cover or head as well?
Thanks
Tom
Thanks
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Last edit: 03 Feb 2009 23:56 by Buda.
- wiredgeorge
03 Feb 2009 05:54 #261874
by wiredgeorge
Replied by wiredgeorge on topic cam cover caps
I believe their reed valve covers will cover anything that needs covering... nothing on the cam cover that needs covering or the head outside what is covered by the cap.
- Buda
03 Feb 2009 23:56 #262079
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Replied by Buda on topic cam cover caps
Thanks
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
