locktight on cam bolts
  • Buda
  • Buda's Avatar Topic Author
01 Feb 2009 11:25
#261515
Should I use locktight on my cam bolts and witch locktight?
Thanks
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
Re: locktight on cam bolts
01 Feb 2009 13:27
#261540
Not sure if the same is true on the KZ1000, but the KZ650 FSM does NOT call for locking agent on cam caps. It does call for it on the cam chain guide sprocket bolts. I use the Loctite Blue on my cam chain guide sprocket bolts.
  • gane
  • gane's Avatar
01 Feb 2009 15:35
#261561
I do blue. especially if sprockets are slotted. G
[img][/img] 1977 KZ1000A1
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
01 Feb 2009 16:25
#261573
me too.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • RonKZ650
  • RonKZ650's Avatar
02 Feb 2009 06:39
#261687
Loctite on the spockets to the cam is ok, no need to loctite the camcaps because they have constant pressure from the camshafts that keep them from possibly loosening. I've never heard of one coming loose in any engine.
  • Buda
02 Feb 2009 10:45
#261720
Thanks guys
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
  • MFolks
  • MFolks's Avatar
02 Feb 2009 13:46
#261752
The Blue Loctite #242 is removable with hand tools and resists vibration. It's the Red #222 you want to stay away from. It requires about 400F to loosen up and is considered permante.
  • timebomb33
  • timebomb33's Avatar
02 Feb 2009 17:07
#261785
the red will break loose with air tools usally but stay with the blue and yes make sure you loctite the cam sprocket bolts it will save you a motor down the road ,speaking from experiance use my problems as a learning tool.
I THINK MY POWERBAND BROKE
  • wiredgeorge
  • wiredgeorge's Avatar
03 Feb 2009 06:07
#261879
The man asked about the bolts that hold the cam caps. These should never be loctited. It is OK to loctite the bolts that hold the sprockets but that isn't what he wants to know. The cam cap thread where the bolts go strips too easily as it is. I would also consider using less torque on them than is called for in the factory service manual or just put inserts in from the get-go and be done with it.
  • timebomb33
03 Feb 2009 07:17
#261889
he said cam bolts,not cam cap bolts
