- Thank you received: 5
Andrews 2X cams question
- Gman
01 Feb 2009 06:37 #261403
by Gman
1978 KZ1000
1965 Harly Electra Glide
2002 Gold Wing
1974 Z1 900 project
Andrews 2X cams question was created by Gman
Does anyone know if Andrews 2X cams have stock base circles? I searched and googled but haven't found this spec. Looking at cam options for my 1015 10:25 to 1 street motor. Thanks.
1978 KZ1000
2002 Gold Wing
1974 Z1 900 project
- otakar
01 Feb 2009 06:43 #261407
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Andrews 2X cams question
YES 2X are a direct drop in. Lift.360 Duration 258* Intake 23/55 Exhaust 55/23 they will give a mild boost to any stock 900 or 1000 pre 1979.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- austin3119
- Thank you received: 7
01 Feb 2009 06:49 #261410
by austin3119
Replied by austin3119 on topic Andrews 2X cams question
- Gman
01 Feb 2009 07:00 #261418
by Gman
1978 KZ1000
2002 Gold Wing
1974 Z1 900 project
Replied by Gman on topic Andrews 2X cams question
Thanks. I saw those specs but I see nothing that gives the base circle dimensions. Am I missing something?
1978 KZ1000
2002 Gold Wing
1974 Z1 900 project
- timebomb33
- Thank you received: 10
01 Feb 2009 07:06 #261423
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Andrews 2X cams question
they stay with the stock base circle until they get in to the really radical cam profiles the stock base circle measurement is 1.10 inch the only time that might change is if the cams are regrinds. but i'm pretty sure andrews cams weren't regrinds and i know for a fact web cams are not either.
- otakar
01 Feb 2009 07:09 #261426
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
I have a set sitting right in front of me and yes they are stock. The only reason that a cam manufacturer would change the base circle from stock, would be to shrink it and therefore be able to increase the lift range. This is only done on cams which are more than .440 lift.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Gman
01 Feb 2009 10:56 #261510
by Gman
1978 KZ1000
2002 Gold Wing
1974 Z1 900 project
Thanks a lot for confirming for me.
1978 KZ1000
2002 Gold Wing
1974 Z1 900 project
