kz650 810cc big bore kit !!!
- kz1000ltd
24 Feb 2006 11:46
Ok i have a 1978 kz650 SR and it has the 810cc big bore kit installed. 650 head ,stock cams,and im going to run 28mm z1900 carbs with k&n pods, vance & hines 4 into 1 exhaust system. I also installed dyna 3ohm coils and dyna s electronic system. My question is on the carbs. What size piolet jets and main jets would be best for this setup???? Any info will be very helpful..........thanks everyone in advance.....:blink:
- galaxian
Re: kz650 810cc big bore kit !!!
24 Feb 2006 14:21
Can you list the specs on your big bore kit?? Like who the pistons are made by and all. I have only seen the 720 kit for the 650. The 810 is usually made for the 750.
1977 KZ1000A1, 1979 KZ650 C3
- 77KZ650
24 Feb 2006 19:51
He would be using the 750 jugs, as they will be a bolt on for the later yrs (I think), or can be made to fit the earlier yrs by enlarging the holes in the top case to accept the larger sleaves, or he had the 650 sleaves presed out, block bored to accept 750 sleaves, then those bored to the 810 kit. probly the wiseco k810 kit, 69mm, 10.25-1 comp (although it should be higher with the smaller combustion chamber of the 650 head)
Read about my project in my sig
Scott
Post edited by: 77KZ650, at: 2006/02/24 22:53
Scott
07 MDP Rookie of the Year
- twowheeledterror
24 Feb 2006 22:20
galaxian wrote:
I've got a 784cc big bore kit for my 650. Old kit that MTC used to make. :thumbup:
- Old-Skul
27 Feb 2006 13:28
I think I am running 120 main jets in my motor. It's a 700CC with lots more cam than yours and 29mm smoothbore carbs. Since you have lots more displacement but less cam this may be a decent starting point for you. The two might equal out to some degree. Needles are in the second position from the bottom I think as well.
- RandomKZ650
14 Aug 2016 17:04
Are 650 sleeves thick enough to be bored out to 66mm for 750cc ?
77 kz650 C1
- Nebr_Rex
14 Aug 2016 17:10
No.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- RandomKZ650
14 Aug 2016 18:09 - 14 Aug 2016 18:11
Quick answer haha.
Nowbwhen modifying an earlier kz650 motor with roller chain, besides having to bore out the cases a bit. Can you use the roller chain wheels in the kz750 cylinders (hyvo chain) or must you use hyvo sliders ?
77 kz650 C1
Last edit: 14 Aug 2016 18:11 by RandomKZ650.
- KZB2 650
15 Aug 2016 06:24
Can't use the hyvo (later style) chain on the earlier crank so you need to keep the older style chain set up...... like said a 1980 or possibly a 81 block for the 750 is the only one that has the cut outs for the old rollers. 700cc kit is the only size that will fit the 650 block unless like said you have liners installed which would be pretty pricey. They did away with the 720 and 740 kit probably cause things were getting too thin. Search for 810 kit in 650 lots of info on here and else where.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- RandomKZ650
15 Aug 2016 08:50
Yea definitely not going the double bore route, boring cylinder block then cylinder sleeves. I know you can't use the hyvo chain on the a roller style crank, but if I use a newer style block can I use the sliders that block would normally use, keeping the roller chain, or does the block have the slots for the older style rollers ?
I want to be clear cause I plan on using a 700 block bored to 65mm and that block uses sliders not rollers. If I can use the rollers I will, but if I can't I'll use the sliders which would probably amount to less wear of the cam chain, although it's in constant lubrication, so wear probably isn't a factor
77 kz650 C1
