Are kz 550-650 engine parts interchangeable?
- jeff mckinney
30 Jan 2009 08:11
I'm guessing not but hoping so,specifically 650 cyl & head on 550 cases
- Mcdroid
- Gone Kwackers
Re: Are kz 550-650 engine parts interchangeable?
30 Jan 2009 08:28
The short answer is no...the bikes that can be somewhat interchangeable motorwise are the 650 and 750
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- TODDSTER
- Die Hard & Live Free
30 Jan 2009 19:48
so i cuold put a 750 head on a 650 motor with 750 pistons and cams. how wuold that work with carberation,etc.etc. ?
KZ 78 650 SR D1a W/78 Quick silver 3/4 stock fairing, new dunlop rubber frnt. & back, new jcw rear shocks, new progressive frt. fork springs & 1 ground-hog to my credit.(ouch)
TODDSTER in N.Western PA
Kawi Strong w/windshield in my face
- steell
31 Jan 2009 04:18
TODDSTER wrote:
Reborn650 has a 650 with 750 cylinder block and pistons (bored to 810), but he used a 650 head. I think he has 29mm smoothbore carbs though.
Dave Sloan has a 750 head and block bored to 810 on his 650, but he has MegaSquirt EFI on it.
I think Jordan is using BS34 carbs on his, but I'm not sure.
It's possible to use the stock 650 carbs when using 750 (or 810) cylinders and head on a 650, just can't think of anyone that did at the moment.
I don't know what you mean by etc, etc though, everything else is pretty much bolt on.
Search the site, this subject has been covered in detail (ie: beat to death)
- JMKZHI
31 Jan 2009 07:00
Concerning the etc part....
Will the airbox on a 70s 650 work w the BS32 or BS34 carbs? I've never verified this, but the middle holes may be smaller in diameter than the outer holes?
- mariozappa
31 Jan 2009 07:17
Can't say about the BS carbs, but the airbox box the CV34 carbs has much larger holes than the 650 VM24 airbox. You could probably cut new/larger holes. I'm using a CV34 airbox from a 750 (with CV34 carbs)in a 650 frame.
1977 KZ650C1
and the KZ650/KZ750 Conversion
- JMKZHI
31 Jan 2009 08:13 - 31 Jan 2009 08:14
The 81 KZ650-CSR came stock w VM24 carbs, but has the same airbox as the later CSR models w BS32s and the KZ750-4s (not sure what carbs those bikes have).
Last edit: 31 Jan 2009 08:14 by JMKZHI.
- SPARKY47
- 1980 KZ500 B2
31 Jan 2009 08:18
I've got a few bits off 650's on my 500,including the pickup plate and ignitor, hoping it'll go FASTER:woohoo:
1980 KZ500 B2
