- Thank you received: 3
Appx. Compression pressure chart
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
27 Jan 2009 15:26 - 27 Jan 2009 16:26 #260512
by kzz1p
Appx. Compression pressure chart was created by kzz1p
I have had this chart for years and years. I got it out of a motorcycle repair book.It is Approximate Compression Pressure while cranking slowly.I am not saying it is correct or ture. Just something to think about when buying cams or changing cam timing.Find your compression ratio across the top and the "Closing" of your intake valve down the left side of the chart.
Last edit: 27 Jan 2009 16:26 by kzz1p.
- kzz1p
01 Apr 2009 12:17 - 01 Apr 2009 12:20 #277432
by kzz1p
Replied by kzz1p on topic Appx. Compression pressure chart
Last edit: 01 Apr 2009 12:20 by kzz1p.
- mark1122
- Keep twisting it
- Thank you received: 109
01 Apr 2009 12:50 #277443
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic Appx. Compression pressure chart
Those #'s do seem high. i have 10:1's , intake closes at 60* abdc. so i should have 238psi.
I'll let you know what i get after the restart.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
