- Thank you received: 1
cam chain sprockets
- HOGEATER
- Been riding 2 wheels since 1965,
- mark1122
- Keep twisting it
- Thank you received: 109
That would be tough to do.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- racer54
- Thank you received: 114
- HOGEATER
Or who near NC would split the cases and rebuild for me??
- PLUMMEN
- Thank you received: 104
- Thank you received: 2829
- gane
[img][/img] 1977 KZ1000A1
- jzanutto
1978 KZ650B 2004 BMW R1150RT
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
- Old Man Rock
- Thank you received: 225
You will need to do the following...
Remove tank, valve cover, exhaust and carbs.
Remove cam chain tensioner.
Remove camshafts and head.
Lift off cylinder (maybe not).
Spread the timing chain as much as possible while viewing with flash light down into the lower case...
Take off the ignition cover and with the 17mm larger nut, slowly rotate the crank a couple of teeth at a time... Rotate completely around while seeing if you can find the broken tooth or worse...
You may or may not get lucky
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- keith1
There may be one way but not as good as splitting the cases for 100% confirmations...
that would be the way i would do it.....
