78 kz 650 Valve shims needed can trade or pay!
- odl666
25 Jan 2009 13:38 #260107
by odl666
1978 kz 650b with gpz faq mods cams carbs polished and ported
1979 gs750e
1972 bsa lightning under construction
78 kz 650 Valve shims needed can trade or pay! was created by odl666
I am needeing some valve shims and i would send back what ever ones i do not use. I can also trade for ones i do have. I beleive i have 2- 235 3- 240 4-245 also maybe more than posted ad well as some 250 shims. i am needing 4 220 shims and four 225 shims also maybe a couple of 215 and 210 jsut to be safe. Like i said i can send whatever i don't use back to you and trade for the shims i do have. Kinda in a rush and i would gladly pay for priority shipping through usps (paypal). Thanks for any help!
1979 gs750e
- bountyhunter
- Thank you received: 337
25 Jan 2009 15:34 - 25 Jan 2009 15:35 #260127
by bountyhunter
Replied by bountyhunter on topic 78 kz 650 Valve shims needed can trade or pay!
A local Kawi dealer will probably trade you some shims because I do believe these are still available from many sources (unlike the shims for the 750 twins).
If you have to buy shims, Bike bandit sells the OEM originals for about $5.90 each. Z1 Enterprises may also have them.
Last edit: 25 Jan 2009 15:35 by bountyhunter.
- keith1
- Thank you received: 2
25 Jan 2009 15:51 #260133
by keith1
Replied by keith1 on topic 78 kz 650 Valve shims needed can trade or pay!
are the ones for the 650 same as 1000 s...?
- loudhvx
- Thank you received: 1616
25 Jan 2009 16:00 #260137
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic 78 kz 650 Valve shims needed can trade or pay!
550's, 650's and 750-fours use the same shims. The older bigger motors can be converted to the shim-under-bucket type, but normally they were shim over (which requires bigger shims).
1981 KZ550 D1 gpz.
Other links.
- keith1
25 Jan 2009 17:03 #260162
by keith1
loudhvx wrote:
thanks for the clarification....just wondering if i would be of any help regarding his dilemma....keith
- odl666
25 Jan 2009 17:06 #260163
by odl666
1979 gs750e
Replied by odl666 on topic 78 kz 650 Valve shims needed can trade or pay!
Thanks for the help any way I don;t like these under bucket shims too much hassel to change them
1979 gs750e
- loudhvx
25 Jan 2009 17:21 #260166
by loudhvx
1981 KZ550 D1 gpz.
Other links.
It is more work, but in the long run, if you ever seen the damage a spit shim can cause on a shim-over, it's a good piece of mind if you miss a shift here or there on a hard launch. I think people use 650 shim-under setups on the 900's for safety.
1981 KZ550 D1 gpz.
Other links.
