- Thank you received: 5
Cam Chain Guide Replace?
- Gman
25 Jan 2009 06:27 #260041
by Gman
1978 KZ1000
1965 Harly Electra Glide
2002 Gold Wing
1974 Z1 900 project
Cam Chain Guide Replace? was created by Gman
The cam chain guide on my Z1 has wear marks. Does this one need replaced or is this normal? If it needs replaced, what is the best way to get this screw out without stripping the screw head? I'm worried there is probably loctite on the threads. Thanks.
1978 KZ1000
2002 Gold Wing
1974 Z1 900 project
- keith1
- Thank you received: 2
25 Jan 2009 06:42 #260043
by keith1
Replied by keith1 on topic Cam Chain Guide Replace?
Gman wrote:
you might be able to get an inpact screwdriver in there...make sure you have the right size phillips,
one good smack should do it....if you are replacing the other stuff, may as well do that one too....
- Mcdroid
- Gone Kwackers
- Thank you received: 317
25 Jan 2009 07:28 #260047
by Mcdroid
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Replied by Mcdroid on topic Cam Chain Guide Replace?
Actually, the screw may come out easier than you think...use a quality screwdriver that fits the phillips head to lessen 'round-out' or, as suggested, an impact driver....and replace every bit of the cam chain tensioning series you can, just to be safe and to take opportunity of the current situation...
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Thank you received: 2829
25 Jan 2009 14:23 #260116
by 650ed
Replied by 650ed on topic Cam Chain Guide Replace?
As a precaution, you may want to soak some Kroil around that screw for a couple days before trying to remove it. Ed
- Link14
- Thank you received: 6
25 Jan 2009 14:52 #260120
by Link14
Replied by Link14 on topic Cam Chain Guide Replace?
My thoughts exactly, except I'd use PB blaster and my impact driver. Love that thing....haven't stripped anything since I got it.
- Gman
01 Feb 2009 05:06 - 01 Feb 2009 05:08 #261362
by Gman
1978 KZ1000
2002 Gold Wing
1974 Z1 900 project
Replied by Gman on topic Cam Chain Guide Replace?
Hi. Thought I would give an update in case it is a help to anyone else. I got the screw out yesterday. I bought a Craftsman impact driver but the bits from it were too short to reach. Ended up using a Master Mechanic #3 bit but still had to shim it out in the bit holder so it would reach without interference to the block. Took a lot of pounding to break it loose. Thanks for the suggestions. I get the feeling I will be using the impact driver a lot.
1978 KZ1000
2002 Gold Wing
1974 Z1 900 project
Last edit: 01 Feb 2009 05:08 by Gman. Reason: correct spelling
- timebomb33
- Thank you received: 10
01 Feb 2009 05:24 #261364
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Cam Chain Guide Replace?
if you have to use it more than once it is a good investment just think of the greif and frustration it all ready has saved you. that tool is always one of the first tools i tell every apprentice i have to buy first because it will get used alot until he figures out other ways of doing things.
- gane
01 Feb 2009 16:45 - 01 Feb 2009 16:51 #261580
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic Cam Chain Guide Replace?
Gman, I see little wear there. But if it comforts you, replace. the old "vessel" impact driver is tried & true, and can be used in conjunction w/ 3/8" s extensions to break loose. also, I could be wrong, but believe bottom of that slipper sits in a recess between cyl and cases and requires raising barrels to replace. G
Last edit: 01 Feb 2009 16:51 by gane.
