Timing problem?Air coming out of intake n carbs
- odl666
1978 kz 650b with gpz faq mods cams carbs polished and ported
1979 gs750e
1972 bsa lightning under construction
- Thank you received: 2098
Good Luck!
- odl666
1979 gs750e
Could do a forum search for a procedural walk-through covered in previous threads. (see "Search Box" above).
Am also thinking there's a KZ650 shop manual available in Filebase under "KZ Information" (see green ribbon toward top of screen).
With proper cam timing, decent compression, correct valve clearances, and good valve seating, the cylinder should suck mixture from the carb, and not push anything back through the carb. Imo, anything from the combustion chamber going back through the carb means the intake valve is not tightly closing when it's supposed to.
If had to guess now, would suspect an error during the last camshaft installation.
Good Luck!
- Snakebyte
- odl666
1979 gs750e
May of found the problem my valve clearences seemed to be pretty out of wack i could only get the smallest feeler guage (0.038mm) in on one intake valve. The shim I had in was a 235, I am going to go ahead and change the shim to a smaller size. Does this make sense of what my problem could be? Thanks for all the help.
Any gap at all when cold should allow complete closure of the valve. So imo the 0.038mm gap isn't causing the present symptoms.
odl666 wrote:
...Also valve shims were done after i put togeather motor.....
Am thinking the camshafts were incorrectly re-installed following the most recent shim exchange.
Good Luck!
- odl666
1979 gs750e
But that meadurment was only on one valve the rest had no clearence at all sound like a problem?
Insufficient valve clearance is definitely a problem, and should be corrected before again running the engine.
As earlier noted, too tight intake valve clearance may prevent complete closure when supposed to be seated, thus allowing upward piston movement to push whatever's inside the combustion chamber back out through the carb (even with perfect cam tming).
Good Luck!
These strokes describe the process that's happening in a running engine as the crankshaft rotates and the pistons move up and down.
1 = intake
2 = compression
3 = power
4 = exhaust
stroke 1 = intake
Intake valve is open.
Piston is moving down and sucking mixture from the carb into the combustion chamber through the open intake valve.
Flow through the open intake valve is supposed to always travel toward and into the combustion chamber.
Exhaust valve is closed to prevent unwanted partial sucking from the exhaust.
stroke 2 = compression
Both valves are closed.
Piston is moving up and compressing the mixture that was inhaled in the previous stroke 1.
stroke 3 = power
Both valves remain closed.
Sparkplug fires and ignites the compressed mixture which "explodes" and pushes the piston downward.
stroke 4 = exhaust
Exhaust valve is open.
Piston is moving upward and pushing remains of the exploded mixture from the combustion chamber out through the open exhaust valve.
Flow through the exhaust valve is supposed to always travel away from and out of the combustion chamber.
Intake valve is closed to prevent anything from being pushed through it backward.
If during strokes 2-3-4, the intake valve fails for any reason to completely close against its seat as its supposed to, pressure from inside the combustion chamber is pushed out "backward" through the valve seat and toward the carb. Such failure to seat may be caused by insufficient valve clearance (gap), or a burnt valve, or some other reason.
Correct positioning of the camshaft is necessary to correctly "time" opening and closing of the valves.
Correct valve clearance (gap) -- set with shims -- is to assure that a valve is allowed to fully close in its seat, especially after the engine reaches normal operating temperature.
To see the four strokes in action, click here > Varoom!
To hopefully facilitate easier understanding of the basics involved, have purposefully ignored all the related matters such as overlap, cam profile, duration, ignition timing, exhaust pulses, etc. And thankfully so, as am barely ankle deep in that ocean of knowledge (maybe actually still on dry sand.)
Good Luck!
- nads.com
