- Thank you received: 235
any good tricks..holding blocks for honing,build ?
- trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- PLUMMEN
- Thank you received: 104
- APE Jay
- Banned
- Thank you received: 58
- trianglelaguna
You need to hone it wet. That would make a mess in the bench.
1976 KZ900
2003 ZX12R
2007 FZ1000
- Thank you received: 797
- PLUMMEN
- trianglelaguna
put a barrel under your drill press!:laugh:
1976 KZ900
2003 ZX12R
2007 FZ1000
back to the topic,i use an old 1/2 drive electric drill that the variable trigger is burned out on.i have a light switch rotary dimmer wired into a box with an e-socket that plugs into one of my other e-sockets.anything i plug into the one with the rotary switch i can control the speed(variable speed)with the rotary knob.i have sunnen expandable hone's that i use(flex hones are fine for glaze breaking).you don't want to hone with a drill motor wide open,you can't get a nice crosshatch.it is very hard to give a drill enough "throttle" while trying to keep up a consistent crosshatch.so with the rotary knob you hold the drill wide open and maintain your desired speed with the knob,while keeping a good grip to stroke with.walla b-u-tiful crosshatch.hth
- PLUMMEN
- trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
i have to park next to my company owners boxster s.you would be amzed at how comfortably i swing in next to it nowdays:laugh: .
sounds like you prolly have a pretty cool girlsdad there triangle.
