- Thank you received: 1
650 to 750 conversion
- Becker
- The Doctor Will Rise Again
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
- Becker
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
- OnkelB
- Thank you received: 80
I'm wondering if I can put the 750 pistons and cylinders directly on the 650 bottom end and use the 650 head with no problems or are there going to be issues with fitment??
The short version: no.
The long version: Apart from the 750 sleeves being bigger than the 650 sleeves meaning you will have to grind the cases at the cylinder base to make the 750 block fit physically the 77-80 650s use a single roller cam chain with cam chain sprockets, one at the rear cylinder block top, one at the front cylinder top and one at the top of the head.
The 750s use a multilink (hy-vo) cam chain with sliding blocks, one at the rear of the cylinder block, one at the front of the cylinder block and one sitting in the valve cover.
Apart from the 80 750 (and possibly a few 81 models) the 750 cylinder blocks do not have the provisions for the cam chain sprocket shafts so they won't work with a single roller cam chain. The only way to get around this is to use a 750 crank, post-80 750 cylinder block, 750 valve cover, 750 cams (or cam sprockets) and a 750 multilink (hy-vo) cam chain which basically means that you have to rebuild your 650 engine into a 750. It can be done if you really want it, but it would be far cheaper to get hold of a complete 750 engine that will bolt right in.
Or even better, a complete GPz 750 engine, it bolts right in your 650 frame with a few spacers (Steell will know) and gives you 85 crank hp out of the box.
77 KZ 650 B1, 82 GPz 1100 B2.
- steell
At this point in time it looks like the 80-82 KZ750E and H models have the provisions for the 650's roller cam chain. The 83-85 GPz750 models definitely do not have these provisions, 83 Spectre I don't know.
Becker, post a pic of the top of the cylinder block and we can tell you for certain if it will work, and at the same time expand our knowledge base.
I have my camera sitting next to me, and a 81 750H cylinder block sitting on the floor next to me, so I took a pic
If the top of your cylinder block looks exactly like this one, then you're good to go. The difference is the front of the cam chain tunnel.
Rear may be different also, I forget.
- Becker
Here is a photo of the block and pistons that I got. It looks like it must use a hyvo chain because I can't see any provisions for the rollers. I knew there was something goofy about the chain fitment but I wasn't sure what it is. Well I guess I'll just have to keep it a stock 650. not that big of a deal. Thanks for all of your help though.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
- kawsakiman
- Thank you received: 6
but you will still have to have the upper case milled to accept the larger sleeves.
- steell
All 750 fours use a HyVo cam chain, it's just that some of them also have provisions for the roller chain of the 650's.
- OnkelB
OnkelB, I've done some more research, and had the opportunity to tear down a few more 750 four motors, since we had this discussion.
Good info Steve, I didn't know that the provisions on the 750 blocks were present as late as 82.
Oddly enough, while the 400s/650s/900s/1000s and the GPz line were very popular over here (Denmark), the 750s never really caught on - I'm 49 and I've only ever seen two in person, one four and one twin, guess the CB 750s covered that market.
- Snakebyte
- Thank you received: 2
You can bore the top of your case with a dremmel dont have to be perfect cause you have dolls to line every thing up.
cgi.ebay.com/ebaymotors/1981-KZ-750-Cran...fPartsQ5fAccessories
