"complete" engine gasket set?
- jzanutto
19 Jan 2009 18:42 #258875
by jzanutto
1978 KZ650B 2004 BMW R1150RT
"complete" engine gasket set? was created by jzanutto
so a "complete" engine gasket set doesnt have any bottom end O rings??
- timebomb33
- Thank you received: 10
19 Jan 2009 19:53 #258892
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic "complete" engine gasket set?
they come with all the engine o-rings but not usally case seals like the shift shaft or output shaft that kind of thing you usally have to buy them seperate
- Buda
19 Jan 2009 20:03 #258896
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
Replied by Buda on topic "complete" engine gasket set?
Mine c ame with
cam cover gasket
reed valve gasket
head gasket
valve seals
tensioner o ring
cylinder base gasket
cylinder rubber gasket
exhaust rings
transmission cover gasket?
clutch cover gasket
clutch adjuster gasket
pulsing collcover gasket
generator cover gasket
rh engine cover gasket
oil pan gasket
oil pump gaSKET
oil cooler fitting o ring 2
black plug o ring
oil filler cap o ring
pressure switch o ring
I had to get the oil seals seperatly.
Tom
cam cover gasket
reed valve gasket
head gasket
valve seals
tensioner o ring
exhaust rings
clutch cover gasket
oil pan gasket
oil pump gaSKET
black plug o ring
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- jzanutto
19 Jan 2009 20:59 #258910
by jzanutto
Replied by jzanutto on topic "complete" engine gasket set?
I need the 2 really big ones, there is one on the oil filter cap, then when you split the case there is another one thats the same diameter, up against the case halves. Its like 4 inches diameter...
- jzanutto
19 Jan 2009 21:04 #258911
by jzanutto
- Buda
19 Jan 2009 22:36 #258927
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
I could be wrong but I think 18 comes with the oil filter.
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- Mcdroid
- Gone Kwackers
- Thank you received: 317
20 Jan 2009 01:26 #258941
by Mcdroid
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Replied by Mcdroid on topic "complete" engine gasket set?
thomas ed wrote:
Correct, I buy Fram filters and the filter o-rings are included w/the filter.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
