- Thank you received: 2098
My Valves and Pistons - Feedback Please
...think I should replace the seals at this point if it doesn't appear that oil has been leaking down?
Now would be a good time to go ahead and replace the seals, regardless of appearances. If the old seals aren't leaking now, they likely will be soon.
Good Luck!
- HerrDeacon
- Thank you received: 1
- mark1122
- Keep twisting it
- Thank you received: 109
if u need guides u will need a valves job.When the guides are replaced the valves will no longer seat properly.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- HerrDeacon
- keith1
- bountyhunter
- Thank you received: 337
I found new valves for mine on ebay for about $12 each. At that price, I didn't screw around with cleaning the old ones.What do you guys use to clean the valves? I soaked them in Seafoam last night and used a wire wheel on my Dremel tonight. The intakes are not too bad and I should be able to clean them up, but the exhaust ones are really baked on good. Any tips?
If you use a wire brush, be careful not to score the valve face.
- nads.com
- HerrDeacon
Great tips on the valves nads, thanks. Sounds like a good test for sealing (quicker than waiting overnight too!).
- Old Man Rock
- Thank you received: 225
For a little extra $$$, why not just get a valve job done... All new parts, springs, guides, seals... plus new gaskets of course.
You can probably get this all accomplished for $500 or under pending the valve job, basic or port & polish as well...
Of course if you already have the spring compression tool, reamer and honing tool, guide driver and lapping tools just do it yourself... Parts only for ~ $100 (guides and seals).
Please provide images & text updates as you go... Never have done this myself (valve job), be interesting to see the work in progress...
I don't have all the proper tools or knowledge for that matter, so off to Cavanaughs... Glad I did!
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- HerrDeacon
One good thing is that I'm learning loads (thanks to you guys) and having fun. So as long as I can get it cleaner than before I'll be happy
Great pics OMR, that work looks great, super clean. I doubt mine will look like that. I'll be sure to update as I go.
- BSKZ650
- Thank you received: 14
at this time you can bench adj the valves, this will save you time on the reassembly.
also make sure to lubricate the valves going back in the guides, this is prob the last place that gets oil from the engine on a start up
77 ltd1000, current rider
76 kz900, just waiting
- HerrDeacon
Thanks
