Cam ft lbs setting
- School Teacher
16 Jan 2009 18:18 #258331
by School Teacher
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
Cam ft lbs setting was created by School Teacher
ape sprockets............. kz900...........how many ft lbs?
thanks in advance!
thanks in advance!
1980 kz1000G1
- keith1
- Thank you received: 2
16 Jan 2009 18:34 #258336
by keith1
Replied by keith1 on topic Cam ft lbs setting
not sure on ft/lbs....but use red locker on them.....
- gane
- Thank you received: 1
16 Jan 2009 18:46 #258341
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic Cam ft lbs setting
ST, cam sprokets are usually @ 12 ft/lbs w/ blue or red locktite, give them a call, and be sure. as a worthless asside, cams are hard, true, and brittle. I once broke the sprocket mount tab on a brand new cam thinking it was in place wilst torguing. G
- Old Man Rock
- Thank you received: 225
17 Jan 2009 02:38 #258380
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Cam ft lbs setting
I just went through this process (CAM Degreeing)...
11-12 ft lbs is the spec...
My WebCam camshafts came with their own brand lock-tite. In speaking with others, BLUE lock-tite was the recommendation due to after new cam chain stretching I'll want to go back and re-adjust for lobe centering adjustments...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- timebomb33
- Thank you received: 10
17 Jan 2009 16:17 #258445
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Cam ft lbs setting
yes that is the reason i never degree the cams until it has been run a bit when you install new cam gear componets.
- School Teacher
19 Jan 2009 22:25 #258925
by School Teacher
1980 kz1000G1
Replied by School Teacher on topic Cam ft lbs setting
Thanks guys!
1980 kz1000G1
- PLUMMEN
- Thank you received: 104
19 Jan 2009 22:43 #258931
by PLUMMEN
Replied by PLUMMEN on topic Cam ft lbs setting
Old Man Rock wrote:
ride the damn thing!!!!!!!!!!!!!!!!!!!1:laugh:I just went through this process (CAM Degreeing)...
OMR
