Checking compression
- shighley
\'74 Z1-A, Bought new, worn out 3 times, being ridden now
\'83 XVZ12TK, was daily driver until frame broke
\'78 KZ650SR-D1A, Son's bike, I'm the wrench (He's young)!
- rdgrnr
77 KZ650B1
80 440 LTD Sold
78 GL1000 Naked Wing Sold
80 CM400E Sold
Brainerd, MN
- CoreyClough
- GPz550 Addiction
- Thank you received: 80
5 compression pulses as recommended above should be good enough. I thought the reading on first pulse was supposed to mean something? I could be wrong.
Make sure the battery is completely charged, for stronger cranking.
'85 GPz550(ZX550-A2)
- JR
- Thank you received: 448
If I know the following:
Bore = 66mm (2.598 inch)
Stroke = 54mm (2.126 inch)
Compression ratio 9.0:1
Total Displacement 738cc, 4 cylinders
is it possible to calculate what the compression should be ?
No problem, just curious.
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- timebomb33
- bountyhunter
- Thank you received: 337
Speaking of compression.
I think you have to know the cylinder area volume when the piston is at TDC then compare to the volume when the piston is at the bottom. At bottom when the intake valve is open, it's basically atmospheric pressure in there which is about 14.7 psi. Then when the piston rises it squeezes it into a smaller volume so I think the final PSI is the ratio of the first to final volumes multiplied times the initial 14.7. I could be wrong, it's been 40 years since I took chemistry, but the law is:
P V = n R T
It shows that volume and pressure vary as inverse.
- PLUMMEN
- Thank you received: 104
- Snakebyte
- Thank you received: 2
- JR
I think then that the answer would be no - I cant use a simple calculation. I forgot to consider valves opening nd closing and shape of piston tops and crowns etc. Not as simple as I thought it might be.
As I mentioned I dont have any worries. My compression is 145 across all cylinders on a cold engine. Sometimes practice (measurement) is preferable to theory
Cheers
