turnning over the kz1100 by hand
- mshawn
15 Jan 2009 13:51 #258086
by mshawn
turnning over the kz1100 by hand was created by mshawn
hey is there a way to turn over the kz1100 ltd by hand to see if it is froze up or not it is an 84 b-1 zn1100
thanks guys
thanks guys
- MFolks
- Thank you received: 540
15 Jan 2009 14:08 #258089
by MFolks
Replied by MFolks on topic turnning over the kz1100 by hand
Two ways of doing this:
Remove the four sparkplugs,remove the CD sized cover on the right side of the engine(the old point cover) and take a 17MM wrench rotate the engine to the right. If resistance is felt, then further investigation is needed.
The other way is to remove the left side engine case(the alternator side) and turn the engine over using the bolt holding the alternator rotor(again with the plugs out). This might require a new gasket for that side as the old one may tear/leak later.
- mark1122
- Keep twisting it
- Thank you received: 109
15 Jan 2009 14:20 #258091
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic turnning over the kz1100 by hand
If u suspect a hard time use the left side.Right side bolt is easy to break.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- trianglelaguna
- Thank you received: 235
15 Jan 2009 14:33 #258094
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic turnning over the kz1100 by hand
he aint kidding i finally broke one and was bummin...see my recent thread on replacing crank end sheer pins....i really was not turning that hard(i've turned harder in the past and not snapped one)good luck...
1976 KZ900
2003 ZX12R
2007 FZ1000
- PLUMMEN
- Thank you received: 104
15 Jan 2009 16:49 #258120
by PLUMMEN
Replied by PLUMMEN on topic turnning over the kz1100 by hand
does ithave a kickstarter?
- Old Man Rock
- Thank you received: 225
15 Jan 2009 17:18 #258127
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic turnning over the kz1100 by hand
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- gane
15 Jan 2009 18:08 #258141
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic turnning over the kz1100 by hand
All good posts, an addition.if seisure/dropped valve is suspect, kick starter na, elevate rear wheel/plugs out/p/u cover off /2nd gear, attempt to rotate rear wheel for-aft. G
