750 motor into a 650
- judgie
do i put the whole motor in or just swap the top ends over?
the new motor has no carbs with it, so what do i need to look for?
was going to strip the 750 down anyway and give it a freeshen up with poss a flowed head at the same time.
any more tweeks worth doing while its all aprt?
cheers rob
forever tweeking aircooled engines, well it is my job
77 z650c1
- mariozappa
- Thank you received: 8
1977 KZ650C1
and the KZ650/KZ750 Conversion
- OnkelB
- Thank you received: 80
77 KZ 650 B1, 82 GPz 1100 B2.
- trianglelaguna
- Thank you received: 235
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- steell
Unless you have a solid state replacement reg/rec, I would use the 750 reg/rec and do the minor rewiring.
The 750 has electronic ignition also, so you need to find a stock 750 igniter (or make one). Or you could take a step backwards and use a Dyna S.
Or convert the 750 to the 650 points system (not on a bet!)
- judgie
what carbs do i need to look for as the engine has none on it?
77 z650c1
- OnkelB
If you replace the 750 stator with the 77 650 stator, I'm pretty sure you will have to swap the 650 stator cover onto the 750 also.
Correct, the 750 stator cover does not have the provision for the field coil.
That would be my choice too.
Yeah, good point, I didn't think of that.
- mariozappa
1977 KZ650C1
- judgie
77 z650c1
- mariozappa
1977 KZ650C1
