1000j in an earlier kz900/1000 frame?
- adamnphx
12 Jan 2009 10:19 #257493
by adamnphx
76 kz900, 81kz1000, 66 triumph chop
1000j in an earlier kz900/1000 frame? was created by adamnphx
i am aware of the internal differences but dont know if the mounts are the same. would a j model 1000 go into an earlier frame using the same mounts? thanks adam
- oldkaws4ever
- Have no regrets...... You only live once.
- Thank you received: 12
12 Jan 2009 11:12 #257499
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Replied by oldkaws4ever on topic 1000j in an earlier kz900/1000 frame?
Physically it will fit, but you will have to make different motor mounts. Shouldnt be that hard if you have the right tools.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- StreetfighterKz
- Thank you received: 117
12 Jan 2009 11:25 #257503
by StreetfighterKz
1978 z1000 Streetfighter
1976 z900 Stripfighter (work in progress)
1983 Gpz750 Resto-Mod
1989 Vmax
Replied by StreetfighterKz on topic 1000j in an earlier kz900/1000 frame?
Welcome. Try using the "Search Forum" function in the top right corner of the screen. I just responded to this not too long ago and I'm sure that most if not all the info you need is already on here somewhere.
Later, Doug
Later, Doug
1989 Vmax
- trianglelaguna
- Thank you received: 235
12 Jan 2009 18:27 #257562
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic 1000j in an earlier kz900/1000 frame?
hey adamnphx,
i had asked a similar question and did not find much on it but when i saw your question ....i lokked in the history and found the thread on 1100 engine mounts and restarted it you may have to personal message one of those guys to get more info.....good luck...peace craig
1976 KZ900
2003 ZX12R
2007 FZ1000
- steell
12 Jan 2009 18:56 - 12 Jan 2009 19:01 #257574
by steell
Replied by steell on topic 1000j in an earlier kz900/1000 frame?
trianglelaguna wrote:
Where is the thread and can you post a link??
I'd just like to read it
Found it!!
kzrider.com/index.php?option=com_kunena&...iew&catid=5&id=76360
hey adamnphx,
i lokked in the history and found the thread on 1100 engine mounts and restarted it craig
Found it!!
Last edit: 12 Jan 2009 19:01 by steell.
