- Thank you received: 1
Andrews 2X cams in stock KZ900 engine
- EricHa
12 Jan 2009 07:36 #257468
by EricHa
1977 Kawasaki KZ900A5
1975 Honda CB550K
1996 Ducati 900SS CR
Andrews 2X cams in stock KZ900 engine was created by EricHa
I just scored a set of these cams. Will they work well with a stock 900cc engine, 28mm Z1R carbs, pods, and pipe? I know that a street port would probably be ideal, but that will have to wait.
1975 Honda CB550K
- martijn
12 Jan 2009 07:41 #257469
by martijn
Replied by martijn on topic Andrews 2X cams in stock KZ900 engine
yes.. but try to get adjustable sprockets...
- Sandy
- Fly High,Tony
- Thank you received: 13
12 Jan 2009 07:44 #257470
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic Andrews 2X cams in stock KZ900 engine
martijn wrote:
Yes,to get the full potential out of those cams,get them degreed.You'll be impressed.
And some heavy-duty valve springs.
1977 KZ1000 A-1
- EricHa
12 Jan 2009 08:07 #257476
by EricHa
1975 Honda CB550K
Replied by EricHa on topic Andrews 2X cams in stock KZ900 engine
Sandy wrote:
Thanks for the responses. That's good to here. I've usually seen these used with 1015 and larger engines with some porting. Good to know that they'll work on a 903. I plan to get some APE sprockets and will degree them in.
1975 Honda CB550K
- PLUMMEN
- Thank you received: 104
12 Jan 2009 09:15 #257484
by PLUMMEN
Replied by PLUMMEN on topic Andrews 2X cams in stock KZ900 engine
didnt those use to come in a kit with wiseco pistons years ago?
