- Thank you received: 1
1977 KZ1000 A1
- gane
11 Jan 2009 23:58 #257440
by gane
[img][/img] 1977 KZ1000A1
1977 KZ1000 A1 was created by gane
All, Academic question... I bought This bike under a "distressed sale" Sorry, no pic's. No tank, sidecovers,seat.or exhaust. and crank only rotated @ 30 degrees for @ aft. still, for $100.00 w/title I bit. Speedo indicated 50K miles. Teardown revealed bent valves,worn out cam chain and missing bits. w/cyls/pistons within spec (just)and bottom end clogged w/barely viscous goo. still, trans was good, cl basket fair and oil pump/crank same. So... new valves, fresh seats, rings and hone, cam chain, chicklets tensionor rubber bits, gaskets/seals, and blah blah. compression 120-140 across board, leakdown 2-4%. mostly rings. ign. stock (points) w/29 smoothbores,oval K&N's, and Kerker street exhaust. a summer of riding was pleasant, tho seemed soft.so, prior to launching into jetting/ign. put it on the dyno. Lo, corrected hp is only 72 hp. even w/ sloppy bore, I'd have thought 80, Am I being un realistic? I'm at 5k ft, and temp was @ 40dgrees, EGA #'s @ 3.% idle and @1.50 cruise w@350ppm H/C @ 5k rpm. Thoughts... G
- PLUMMEN
- Thank you received: 104
12 Jan 2009 05:31 #257459
by PLUMMEN
Replied by PLUMMEN on topic 1977 KZ1000 A1
compression is a little off between cylinders ,valves adjusted?other than the numbers being off between cylinders a little that sounds fairly realistic for a basically stock motor with stock head/cams and a loose bore to me anyway.
- timebomb33
12 Jan 2009 09:34 #257488
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic 1977 KZ1000 A1
at that altitude 72 horse for a stock motor is not bad you lose 3% for every thousand feet of elevation so at sea level your motor would make about 84 horse power. so i don't think your to far off.
- gane
13 Jan 2009 18:19 #257752
by gane
Replied by gane on topic 1977 KZ1000 A1
P & T, thanks for 'back... Dyno #'s are corrected for alt, so I guess I'm missing @ 10 hp. I'll continue to fiddle, perhaps a comp baffle and drop needles. Thks g
- arai59
- Banned
13 Jan 2009 19:45 #257769
by arai59
Replied by arai59 on topic 1977 KZ1000 A1
These bikes never made the claimed hp.
- wiredgeorge
14 Jan 2009 07:05 #257826
by wiredgeorge
Replied by wiredgeorge on topic 1977 KZ1000 A1
72 HP is pretty good actually. You will normally see mid to high 60s on most 900cc models.
- EricHa
14 Jan 2009 08:09 #257835
by EricHa
1977 Kawasaki KZ900A5
1975 Honda CB550K
1996 Ducati 900SS CR
Replied by EricHa on topic 1977 KZ1000 A1
Published horsepower numbers were always bhp measured at the crankshaft. Rear wheel horsepower numbers will always be lower.
"Brake horsepower (BHP) is the amount of work generated by a motor without taking into consideration any of the various auxiliary components that may slow down the actual speed of the motor. Sometimes referred to as pure horsepower."
1975 Honda CB550K
- kawtoy
- Thank you received: 6
14 Jan 2009 08:56 #257844
by kawtoy
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
Replied by kawtoy on topic 1977 KZ1000 A1
After I dug my 80 1000 out of storage where it had sat for 15 years I had it dynoed. Stock engine with 4-1 Kerker and jets. It made 75hp in TN which was pretty close to sea level. Bike was blowing a good amount of black smoke so I am sure the rings were shot even though it only had 3,000 miles on it. Sitting that long is never good for an engine. I would say 72hp is just about right for your mods and elevation. You might be able to squeeze another 5hp out of it with a carb sync, coil mod, playing with jetting to find right match for your altitude, and mamybe some adjustable cam gears so you can dial the cams in dead on.
- gane
14 Jan 2009 16:58 #257907
by gane
Again, thanks for feedback. Trying to build a competitive Hot-rod wasn't my intent. My labors were simply to reproduce a bike I coveted and still regard as one of the prettiest made. The periodic nod's I get from current sportbike riders as they slow in mid-pass is nearly as rewarding as the feeling of acompishment of doing all myself. G
- timebomb33
14 Jan 2009 17:34 #257922
by timebomb33
are you happy with how it rides and feels on the road . dyno numbers are just that numbers who cares, if your happy thats all that counts
