81 and 84 GPZ1100 cylinder head comparisons
- barney
11 Jan 2009 11:20
I was wonderin if anyone out there knew off hand what the main differences are between the 1981 cylinder head and the 1984 head. If any
- oldkaws4ever
- Have no regrets...... You only live once.
Re: 81 and 84 GPZ1100 cylinder head comparisons
11 Jan 2009 11:56
Not compleitly sure, but i think the 84 GPZ head had a bigger combustion chamber ie: Bigger valves and such, im sure someone has more info into it than me. I do know that they can be milled to work with the kz bottom end, but it drops the compression 2 full points, so it goes from 8:1 to 6:1, perfect for running a turbo were you need lots a bost to make it scoot. I only know this because Plummen responded to one of my posts about putting the GPZ head on my 74 Z1 900.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- PLUMMEN
11 Jan 2009 15:26 - 11 Jan 2009 15:26
the 81-82 has the hemi type combustion chamber like the older 900-1000 motors but has much bigger combustion chamber than the old kz motors.the 83-84 is a much better design but completely differant and wont work on the older motors without a great deal of money and parts changing including crank/rods and pistons
Last edit: 11 Jan 2009 15:26 by PLUMMEN.
- Mcdroid
- Gone Kwackers
11 Jan 2009 16:06
Be also aware that the 1981 GPz1100 head had the injectors mount directly into the head whereas the injectors were mounted on the throttle bodies starting in 1982. So, if you find a 1981 head, you have to deal with blocking off the injector ports if you run carbs or go with the later style injectors.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- timebomb33
11 Jan 2009 16:23
in order to run the late model gpz head you have to use j rods on the crank as they are .40" shorter [pin heights are different from kz to gpz pistons] and since the combustion chamber is larger you will have to get pistons made up to fit the gpz head or you won't have any compression.
I THINK MY POWERBAND BROKE
- PLUMMEN
11 Jan 2009 16:32 - 11 Jan 2009 16:33
timebomb33 wrote:
slow down youre making my head spin here!:laugh: you can use the 81-82 gpz/81-90 something j head on the old motors depending on which path ya wanna follow.you can just run higher compression kz pistons knowing its going to drop around 2 full points depending on who you ask,or you can use j pistons on the stock kz rods with a spacer under the cylinder to make up for the kz rods.either way you need the cam chain adaptor to make it work.the 83-84 gpz also uses bigger wrist pins so its really cost prohibitive unless you have really deep pockets to make that one work,ive got some 83-84 kz/gpz 1100/1170 pistons someplace that i learned this on the hard way!:laugh:in order to run the late model gpz head you have to use j rods on the crank as they are .40" shorter [pin heights are different from kz to gpz pistons] and since the combustion chamber is larger you will have to get pistons made up to fit the gpz head or you won't have any compression.
Last edit: 11 Jan 2009 16:33 by PLUMMEN.
- barney
11 Jan 2009 16:56
Sorry I didnt explain clearly enough
Im running a 1981 GPZ motor in my ELR(my head has the injector ports in the head- I've already blocked them off and am running carbs).Motor runns great. Problem is , I have a small crack across one of the cam plug holes. I know of a nice 1984 GPZ 1100 head for sale and was wondering if I could just drop it on my 81 J motor .
- PLUMMEN
11 Jan 2009 17:04
totally differant animal,you need an81- j style head
- barney
11 Jan 2009 17:24
Yea but an 1982 gpz head will work also,I know that much. And maybe 1000J heads will work too. Is the combustion chamber volume and valve sizes etc.simular on the 81 and 84 head ?
- PLUMMEN
11 Jan 2009 18:17
totally differant combustion chamber design im thinking the 81-82 gpz and the 81- j head are pretty much same thats why i lump them together.
- steell
11 Jan 2009 19:34
barney wrote:
Why don't you ask Larry Cavan (user name)? Since he does this stuff for a living I'm inclined to think he knows what he's talking about.
www.flowbenchtech.com/porting/CRH/index.htm
Cavanaugh Racing Heads
- APE Jay
11 Jan 2009 20:19 - 11 Jan 2009 20:20
The 83-84 head has what we call the "bath tub" combustion chamber. It also has larger valves.
Not too sure about volume differences, but the shape would mean aftermarket pistons for the early head, might have to be modified to clear the late chamber.
No connecting rods have to be changed.
Jay
Jay
Last edit: 11 Jan 2009 20:20 by APE Jay.
