Valve shims question
10 Jan 2009 22:07 #257188 by dman3998
Valve shims question was created by dman3998
I was checking the valve clearance, (1000 B3) they were all almost the same 265 - 275 all had the same wear about .04mm so I need to get a bunch of 260's and 265's.
My question is one of the shims had "270A" on it I have never seen any with letters. any ideas what it means?
Thanks
Dman
Dman
SE Idaho
"Smart only goes just so far, STUPID is UN-limited"
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
11 Jan 2009 14:04 #257279 by bountyhunter
Replied by bountyhunter on topic Valve shims question
Are you saying the shims showed .04 mm wear as to thickness compared to the marked thickness? That would be very unusual. Did you measure it with a calibrated set of calipers?
I have seen it and I just ignored it. I don't know what it means either. I just measure the thickness and mark them myself since some of mine have the factory marks rubbed off.
11 Jan 2009 16:48 #257307 by keith1
Replied by keith1 on topic Valve shims question
this should explain......keith
www.redlinecycle.com/Valve%20Shims.html
11 Jan 2009 17:32 #257324 by timebomb33
Replied by timebomb33 on topic Valve shims question
thats pretty cool info i've never seen those id markings described or explained before see i knew if i came on here i would learn something new today.
I THINK MY POWERBAND BROKE
11 Jan 2009 17:46 #257329 by keith1
c'mon man...you have probably forgotten more than most know!!!!!!:laugh:
11 Jan 2009 18:03 #257331 by timebomb33
yah probably but it's nice to get a refresher course once in a while.
11 Jan 2009 19:55 #257371 by dman3998
Replied by dman3998 on topic Valve shims question
that is good info. thanks
Dman
SE Idaho
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
15 Jan 2009 20:28 #258164 by luc
Replied by luc on topic Valve shims question
Redlinecycle is wrong regarding the explanation for the "A" on a shim.
It is not, as they said, to denote a slightly thicker shim installed at the factory but rather is is to identify shims that had a stricter QC standards.
Back in June 21 1973, Kawasaki issued a Service Bulletin (73 Z-13) titled "Z1 tapped replacement" to addres the issue of shims faillure due to a combination of shim and tappet design..
The tappet had an oil hole/navel in the center and the shims were flexing on top of it and fracturing.
To solve the problem tappets were replaced with tappets without oil hole/navel and new shims were put in production with a much stricter QC and all bikes in service were supposed to have both tappets and shims replaced regardless of their warranty status.
Kawasaki called that a "factory directed modification" and allowed 1.5 hour for the job
Those shims were identified with the letter "A" but did not have a new or differernt part #.
After a few years,assuming that all the earlier, non "A" shims woud have been removed from service and inventory, Kawasaki dropped the "A".
17 Jan 2009 09:18 #258402 by dman3998
I wonder if we could figure out a way to trade shims?
After re-shimming my motor I have a bunch of extra 270 and 260 shims that I probably will never use. and I still need a 275.
There are enough guys in every country that we would never have to actually buy a new shim. and for less than a buck you could post a couple of shims anywhere in the country.
I'm not sure how it would work but its a concept anyway.
dman
Dman
SE Idaho
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
17 Jan 2009 09:22 #258403 by keith1
dman
thats a good idea...kind of like a shim exchange program....maybe site owner would be willing to set something up....might not be on the top ten list with vendors, but i think the membership might like it.....
17 Jan 2009 13:59 #258428 by bountyhunter
Problem is, sending a small package these days is like $8 which is about what a couple of shims cost.
17 Jan 2009 14:13 #258431 by keith1
true
