Tach Drive Question
- Kawickrice
Tach Drive Question
09 Jan 2009 08:00
I just pulled my tach drive to try to stop a oil leak on a 900. My question is how many o-ring need to be replaced? I know of the one on the out side of the housing that goes in the head. Is there an inner one for the gear shaft or is it similar to the timing cover seal on a small block Chevy?
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- StreetfighterKz
Re: Tach Drive Question
09 Jan 2009 08:25
We used to sell quite a few of the pieces for this at the cycle shop I use to work at. You'll need the o-ring on the outside. Then there is an oil seal on the inside. Later models used a differnt design that need an additional fiber washer but the Z1's do not need it.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- MFolks
09 Jan 2009 12:35
Check with
www.z1enterprises.com
as Jeff knows most things Kawasaki.
- shighley
10 Jan 2009 09:12
Kawickrice; Good information already given. One more thing to check. Look at the pinion gear shaft to make sure there isn't a groove worn where the seal sits. If the wear is too much the unit will leak even with a new seal. Been there, done that. Z1 Enterprises will fix you up for sure. Those guys ship stuff FAST! Ride safe, Steve
PS: Memory tells me there is an additional gasket "disc" that fits inside the tach cable threaded fitting. It's an orange colored gizmo and made from a hard paper type material.
\'74 Z1-A, Bought new, worn out 3 times, being ridden now
\'83 XVZ12TK, was daily driver until frame broke
\'78 KZ650SR-D1A, Son's bike, I'm the wrench (He's young)!
10 Jan 2009 10:49 - 10 Jan 2009 11:44
0-ring - - - The o-ring around the guide supposedly prevents oil from escaping around the guide (between guide and head) to the outside.
Oil seal - - - The rubber oil seal inside the guide has a tiny spring around it to keep a snug fit around the spinning shaft. After enough time, oil and heat, the seal morphs into something like a little chunk of carbon that may require being picked out bit by bit before the new seal will fit properly into position.
Where the shaft hasn't been damaged where it spins inside a good seal, oil won't escape around the shaft to the outside.
With the tach cable disconnected from the guide, and the engine running, the end of the shaft may be watched spinning around, and no oil should be escaping.
So it's fair to ask why bother sealing where the tach cable screws onto the guide? With a brand new tach cable, a seal at this connection probably isn't really necessary. However, if re-fitting the same old tach cable, the cable likely contains remnants of old previously escaped oil which may drool out through an unsealed connection.
Z1 Enterprises carries these tach drive components. Here's a link to the seal.
click > Seal, tach guide
Good Luck!
[Click on diagram for slightly larger view]
Tach part numbers are shown below diagram.
19 92087-5001 GUIDE,TACHOMETER GEAR 1
20 220B0612 SCREW PAN HEAD 6X12 1
21 92050-075 OIL SEAL 1
22 670B1510 "O"RING 10MM 1
23 13223-011 GEAR,TACHOMETER,10T 1
Good Luck!
Last edit: 10 Jan 2009 11:44 by Patton.
