1976-KZ900 Motor fit 1977kz1000 frame
- 1977kz
08 Jan 2009 17:33 #256811
by 1977kz
1976-KZ900 Motor fit 1977kz1000 frame was created by 1977kz
I would like to know if a 1976-kz900 motor will fit a 1977kz 1000 frame with no mods.???
- Jeff.Saunders
08 Jan 2009 17:40 #256813
by Jeff.Saunders
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
Replied by Jeff.Saunders on topic 1976-KZ900 Motor fit 1977kz1000 frame
Yes - one minor difference is the exhaust stud diameter. The 900 uses 6mm studs, the 1000 8mm studs
Z1 Ent on Facebook,
- 1977kz
08 Jan 2009 17:42 #256815
by 1977kz
Replied by 1977kz on topic 1976-KZ900 Motor fit 1977kz1000 frame
Thanks jeff!! so my 1000 header will not fit that 900
- PLUMMEN
- Thank you received: 104
08 Jan 2009 18:20 #256826
by PLUMMEN
Replied by PLUMMEN on topic 1976-KZ900 Motor fit 1977kz1000 frame
header is same ,just use z1- 76 exhuast collars to match the studs if you have them
- Jeff.Saunders
08 Jan 2009 18:52 #256832
by Jeff.Saunders
Z1 Ent on Facebook,
you can use the 1000 exhaust flanges, the hole is a little too large, so you'll need to use a slightly larger washer under the nut.
900 flanges are a better fit - so use those if you have them
Z1 Ent on Facebook,
- 1977kz
08 Jan 2009 19:08 #256837
by 1977kz
Thanks for info. I found a 1976 kz900 motor with a 1075 kit,welded crank and back cut trans also hot cams for 250.00. What do think?
- Bluemeanie
- Thank you received: 14
08 Jan 2009 19:19 #256838
by Bluemeanie
Replied by Bluemeanie on topic 1976-KZ900 Motor fit 1977kz1000 frame
I would say.... SCORE!!
- trianglelaguna
- Thank you received: 235
08 Jan 2009 19:29 #256839
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic 1976-KZ900 Motor fit 1977kz1000 frame
that's a deal.....that's like saying i'm single and this hot chick really likes me...should i talk to her...
1976 KZ900
2003 ZX12R
2007 FZ1000
- Jeff.Saunders
09 Jan 2009 06:19 #256919
by Jeff.Saunders
Z1 Ent on Facebook,
The 900 motors have a lighter cranks, so that motor will rev VERY quick. Not so much torque as you are used to, but it will pull hard and quick to the red-line...
Z1 Ent on Facebook,
- timebomb33
09 Jan 2009 15:52 #257007
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic 1976-KZ900 Motor fit 1977kz1000 frame
250.00 for a running 1075 that rocks buy it or book your self a room at the giggle factory.
- mtkawboy
- Thank you received: 16
10 Jan 2009 14:34 #257127
by mtkawboy
Replied by mtkawboy on topic 1976-KZ900 Motor fit 1977kz1000 frame
I have a 76 1105 motor in a 78 frame. No problems as mentioned, just use the 76 exhaust collars on the pipes
