Engine Paint Removal?
- JAILBAIT
08 Jan 2009 06:45 #256691
by JAILBAIT
Engine Paint Removal? was created by JAILBAIT
What's the best way to get the factory black off the motor?
I want to get it down to bare aluminum so I can have it clear coated.
- image
08 Jan 2009 07:02 #256694
by image
Replied by image on topic Engine Paint Removal?
soda blasting is the most gentle method (won't affect gaskets, rubbers etc)...not sure about where you are, but locally it's also one of the more expensive blast mediums.
- snorules
08 Jan 2009 17:22 #256805
by snorules
1980 KZ550C (daily rider)
1981 KZ1000J (bagger project in progress)
1981 GS1100 (future dragbike)
1978 Z1R (not mine yet, but trying to work out a deal to acquire it).
Replied by snorules on topic Engine Paint Removal?
I just did the engine on my KZ1000J project bike, lots of elbow grease, but relatively cheap and effective. First I completely stripped it down, split the cases and all. Then, I bought some cheap oven cleaner at the dollar store. Sprayed down the parts, scrubbed then with a brass detailing brush,and let soak for about 20 min. Then I sprayed then off with hot water. I had to repeat it about 5-6 times to get most all of the grime and paint off. I then took a die grinder with a brass wire wheel to them. They came out nice. Too bad I'm covering it all up with paint and powdercoat.
- austin3119
- Thank you received: 7
08 Jan 2009 17:48 #256820
by austin3119
Replied by austin3119 on topic Engine Paint Removal?
Just get them bead blasted or soda blasted and be done with it. It will look sweeeeeeeetttt!
