78 650B top end
- jzanutto
78 650B top end
06 Jan 2009 12:41 - 06 Jan 2009 12:42
one piece at a time. Here's the cylinder set all done. Question is: how do the valve guide seals come out? do I just pry them out?
1978 KZ650B 2004 BMW R1150RT
Last edit: 06 Jan 2009 12:42 by jzanutto.
- H2RICK
- Is this a fun bike, or what!!!
Re: 78 650B top end
06 Jan 2009 16:19
Do you mean the valve STEM seals that sit on the end of the valve guide inside the valve springs ??
If so, there is a small clip that must be removed from the seal BEFORE you try removing the seal itself. The clip is there to retain the seal on the end of the valve guide and prevent it from working its way loose.
If you look closely with a strong light at the top portion of the stem seal, you'll see the little wire clip. Once the clip is removed with a little hook-type tool, you can then remove the seal itself, although on a high mileage engine the seal will probably disintegrate because the rubber is so hard.
Be VERY careful removing the seal because it's quite easy to break off the end of the valve guide that the seal sits on/around.
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
- keith1
Re: 78 650B top end
06 Jan 2009 17:01 - 06 Jan 2009 17:02
jzanutto wrote:
just wondering...who did that jug work?.....did you do it yourself?
Last edit: 06 Jan 2009 17:02 by keith1.
- timebomb33
Re: 78 650B top end
06 Jan 2009 17:53
i use 1/2" hose pliers and wiggle it back and forth and they pop right off no muss no fuss.
I THINK MY POWERBAND BROKE
- jzanutto
Re: 78 650B top end
06 Jan 2009 18:10
yeah I do all my own work (well most of it anyway 95%)
yes I'm referring to the valve stem seals. Are they in the complete engine gasket kit?? Who should I buy a complete gasket set from??
Re: 78 650B top end
06 Jan 2009 20:44 - 06 Jan 2009 20:47
Different subject, but I think you were looking for a cam chain roller guide. There's one on eBay; search "nos cam chain roller guide"
Last edit: 06 Jan 2009 20:47 by 650ed.
- jzanutto
- H2RICK
Re: 78 650B top end
07 Jan 2009 09:48
Athena gasket kits contain the stem seals and their overall quality is quite good. They're made in Italy.
The quality of Vesrah kits is spotty. IIRC, they also include the stem seals in their kits. They're made in Taiwan.
There is also an outfit called Cometic making gasket sets but I have never used their stuff so can't comment on their quality or scope of supply in their kits. I'm not positive but I believe they're made in Europe somewhere.
- jzanutto
Re: 78 650B top end
07 Jan 2009 10:46
I've seen anywhere from 50 dollars to 85 for the "complete set"
- bountyhunter
Re: 78 650B top end
07 Jan 2009 13:22
jzanutto wrote:
jzanutto wrote:
Sometimes they do..... sometimes they just say they do and leave you scrambling to find some when the gasket set arrived and you find out THEY LIED...... cough... cough....(ATHENA!)..... cough.......yes I'm referring to the valve stem seals. Are they in the complete engine gasket kit??
jzanutto wrote:
Try Z1 enterprises. If no luck there, Old Bike Barn is a good source. Fleabay has them quite often.Who should I buy a complete gasket set from??
- keith1
Re: 78 650B top end
07 Jan 2009 13:48
jzanutto wrote:
nice job!!
nice job!!
- Injected
Re: 78 650B top end
08 Jan 2009 11:01
If your looking for the best valve guide seals try APE...
the 900/1000 ones will fit and I can tell you that they do not leak oil - they are a better design than OEM and they are thicker so they do not deform over time.
1978 KZ650B2 modified project
