Rubber chain rollers
- jzanutto
04 Jan 2009 18:24 #256188
by jzanutto
1978 KZ650B 2004 BMW R1150RT
Rubber chain rollers was created by jzanutto
- PLUMMEN
- Thank you received: 104
04 Jan 2009 19:20 #256202
by PLUMMEN
Replied by PLUMMEN on topic Rubber chain rollers
which bike?
- jzanutto
04 Jan 2009 20:01 #256213
by jzanutto
Replied by jzanutto on topic Rubber chain rollers
78 KZ650B unknown mileage
- gane
04 Jan 2009 20:51 #256216
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic Rubber chain rollers
J, rubber rollers were originally round.regardless of wear are by now hard.replace them...as well as the chicklets which locate idler gears. also cam chain if over 1/2 of rec. manual wear. also, inspect starter clutch pinoin and rollers.... 650's were notorious hard starters, and starter clutches the 1st to fail.indeed, i would rec. anyone this deep to inspect /replace any starter clutch componants that show ANY wear. luck g
- jzanutto
05 Jan 2009 08:20 #256255
by jzanutto
I got a start clutch for it already. So would you guys re-use these rollers? I guess its not like I can find new ones
- OKC_Kent
- Thank you received: 20
05 Jan 2009 10:23 #256268
by OKC_Kent
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
Replied by OKC_Kent on topic Rubber chain rollers
jzanutto wrote:
Here are a couple threads about 650 cam chain parts. I think the consensus was that the 900/1000 rollers are the same, despite having different part numbers. But please read it for yourself and decide. Ask Onkelb as he did most of the investigation. If they are the same parts then Jeff at Z1Enterprises has parts listed under the 900 area that may be workable on a 650.
kzrider.com/index.php?option=com_kunena&...=43594&catid=2#43594
kzrider.com/index.php?option=com_kunena&...=24052&catid=2#24052
Oklahoma City, OK
- Thank you received: 2829
08 Feb 2009 19:09 - 08 Feb 2009 19:11 #263094
by 650ed
Replied by 650ed on topic jzanutto : Rubber chain rollers
jzanutto, did you ever find a new tensioner assembly? There's one on eBay - Item number: 270341869980
Last edit: 08 Feb 2009 19:11 by 650ed.
- gane
08 Feb 2009 19:25 #263104
by gane
J, thats what all rubber rollers should look like, and are resiliant.chk for new. should be avail. and cheap. G
- timebomb33
08 Feb 2009 19:41 #263110
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Rubber chain rollers
the idler gears can be reused if the bearings and pins are in good shape but definitly change out the rubber idlers and the little rubber blocks holding them in place
