- Thank you received: 235
replacing timing andvance crank shear-pin
- trianglelaguna
i was working on double checking MY 1000j project motor prior to resetting the cams and tensioner(tensioner was hanging by one loose bolt when received}...i took out both cams and the tensoiner and turned the motor over to see if it is free...and hit a little rough spot....like an idiot i sheared the crank timing pin.then i used the stator bolt like i should have...motor is free....i got the peice out of the crank simple with a fine easy out....where can i get the right material for a new one? it is a roll shape shear stock(like a tounge rolled up..lol)with a hole left in the center...my factory shop manual says nothing about r&r of crank pin...and there are no threads here that i could find....any help would be great...i know it is a silly question and asmall piece of roll stock is what i need but i not 100% SURE....THANKS GUYS
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- gane
- Thank you received: 1
[img][/img] 1977 KZ1000A1
- trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
- gane
- trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
- Bluemeanie
- Thank you received: 14
- elseed
I was told to be careful with the EZ out due to the pin likely being hardened -- was surprised how easy it was to remove.
But thing I was gonna say -- I found this part was still available through Kawasaki at like $1.87 or something, got it at my dealer in about three days. I'd do this (and maybe get two?) before I'd use an Ace hardware roll pin.
'75 Z1B with mods
- wiredgeorge
Anyway, get one of the pins that has a slit on the side and compresses. You can tap it in the hole and it will stay just fine. I have had one in for thousands of miles on one of my bikes. I don't recall the name of this type pin. Use an automatic center punch on the broken pin and stay on the pin as it is very hard. An EZ-Out will BREAK so I would highly recommend not using one. If you broke the EZ-Out you will end up with the crank in a machine shop. If you use one of the pins I have used, you will have to cut it off some as it will likely be too long. I used a Dremel tool with cut off wheel.
- trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
- trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
- hammmy
1980 KZ750-4 LTD H1
- trianglelaguna
Out of curiosity, what method did you use to remove the leftover pin?
1976 KZ900
2003 ZX12R
2007 FZ1000
