intermittent lower end knock
- Captaingamez
04 Jan 2009 10:30 #256111
by Captaingamez
1979 Kz1000 MKII road racer project
1994 Seca II, pile in the corner
1973 Honda cb175 cafe racer
1971 Yamaha AT1
1975 Massey Fergusson MF440
1971 Skiroule 300rr
intermittent lower end knock was created by Captaingamez
i got my bike all together enginewise the other day and started it up. started first kick,and purred like a kitten. sounds wonderful. but after running it for about 30 or so seconds i noticed every few seconds at about 1000 rpm it would make a slight lower end knock. the problem doesnt increase with engine speed though. anyone have any ideas? my thoughts were a) not enough oil pressure, b) backfiring or detonating (since i havent rejetted it for the intake or exhaust) or c) cold engine. not too sure as i havent dealt with a vast amount of kz's
1971 Yamaha AT1
1971 Skiroule 300rr
- PLUMMEN
- Thank you received: 104
04 Jan 2009 10:34 #256113
by PLUMMEN
Replied by PLUMMEN on topic intermittent lower end knock
synch your carbs
- Captaingamez
04 Jan 2009 10:39 #256115
by Captaingamez
1971 Yamaha AT1
1971 Skiroule 300rr
Replied by Captaingamez on topic intermittent lower end knock
so you think its just hickuping, as i call it? how do you sync mechanical slides, i have only done it on CV's and cable connected carbs
1971 Yamaha AT1
1971 Skiroule 300rr
- mark1122
- Keep twisting it
- Thank you received: 109
04 Jan 2009 12:15 #256135
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic intermittent lower end knock
There should be screws on top to adjust the slides up and down. you will figure it out pritty quick when u take the caps off. Dif carbs use dif meathods.Hope this helps.
I'm sure there will be details in your manual.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Captaingamez
04 Jan 2009 12:21 #256137
by Captaingamez
1971 Yamaha AT1
1971 Skiroule 300rr
i know the screws your talking about. but i thought taking the caps off while the engine is running would alter the vacuum pressure. i guess then again it wouldnt matter that much if all the caps are off. ill do that then.
1971 Yamaha AT1
1971 Skiroule 300rr
- martijn
04 Jan 2009 12:37 #256142
by martijn
Replied by martijn on topic intermittent lower end knock
how many miles has the clutch done?? might also be loose dampersprings in your clutch basket...
- Captaingamez
04 Jan 2009 12:41 #256143
by Captaingamez
1971 Yamaha AT1
1971 Skiroule 300rr
im assuming its stock, so about 27k
1971 Yamaha AT1
1971 Skiroule 300rr
- gane
04 Jan 2009 17:28 #256171
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic intermittent lower end knock
Capn, light noises from lower end are common at low rpm, usually as M alludes (clutch basket), quick checks, If noise goes away by picking up idle to 1100-1200 rpm, or by slipping into 1st gear and applying light load, be at ease. I've been searching for sewing machine quiet/smooth for years and it's elluded me so far.G
- shighley
05 Jan 2009 06:59 #256244
by shighley
\'74 Z1-A, Bought new, worn out 3 times, being ridden now
\'83 XVZ12TK, was daily driver until frame broke
\'78 KZ650SR-D1A, Son's bike, I'm the wrench (He's young)!
Replied by shighley on topic intermittent lower end knock
A sad/funny tale for you. My '74 Z1A had a similiar "knock" at idle. The sound didn't change when I pulled the clutch in. The motor ran perfect otherwise and since I beat the s**t out of it on a daily basis, I figured I'd damaged something in the lower end, even with the excellent maintainence provided. I tore the motor apart expecting to find a loose rod or main bearing. I didn't find anything except that everything bearing related was just fine. So, what made the knock noise? It ended up that the alternator rotor was the culprit. The aluminum portion that holds the magnets had worked loose from the steel core. There was about .010 to .015" of play. Just enough to make a slight noise. Lesson learned. Check the easy stuff first before tear down. Ride safe, Steve
