popping the head loose
- jzanutto
Most of my engine work is RD400, H1 and H2 - I was wondering what those strange bumps are on top of the engine so I opened it up and found these 2 pieces of unnecessary hardware.... good for boat anchors?
1978 KZ650B 2004 BMW R1150RT
- jzanutto
also, when these engines are fresh, how much timing chain noise should there be?? I'm used to some newer ZX7s, with no noise.
- oldkaws4ever
- Have no regrets...... You only live once.
- Thank you received: 12
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- bountyhunter
- Thank you received: 337
Valve clearance of .003" - .004" is dead perfect for my engine, probably pretty good for yours too.
As for cam chain noise: every rice burner that I hear going down the road including mine has the metallic zing of cam sound in the exhaust note.
- trianglelaguna
- Thank you received: 235
on a kz, at least all the ones i have heard you can always hear the cam chain, but it shouldnt sound like a chainsaw or anything like that. As far as the head goes there should be pry points, that and a few ggod rap's with a rubber mallet should do it.
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- jzanutto
- Thank you received: 2829
- jzanutto
- bountyhunter
there's those 2 little bolts down inside the timing chain galley.... just found them:angry:
OOPS. Mine has three 10mm bolts well hidden threaded upward into the head as well.....:ohmy:
- Thank you received: 2098
...when these engines are fresh, how much timing chain noise should there be?? I'm used to some newer ZX7s, with no noise....
Proper carb sync often significantly reduces cam chain noise.
