Shim kit, build or buy?
- lx460
02 Jan 2009 14:12 #255794
by lx460
2001 KZ1000P
1986 KZ1000P
1981 KZ1000LTD
1980 KZ1000
1988 KZ1000P
See a pattern?
Shim kit, build or buy? was created by lx460
Is it better to buy the kit or build your own by buying individual shims? The clearances don't get smaller so it's unlikely I'll need the larger sizes. Just wondering if I'd be better off buying the smaller ones. I also need the tool first so I don't even know what's in there yet. Any suggestions?
2001 KZ1000P
1986 KZ1000P
1981 KZ1000LTD
1980 KZ1000
1988 KZ1000P
See a pattern?
- racer54
- Thank you received: 114
02 Jan 2009 16:23 #255810
by racer54
Replied by racer54 on topic Shim kit, build or buy?
It would be much cheaper to buy as you need them for sure. I have been buying them over the years and have a decent set now. You would eventually get a good set over time and by buying as you need them, you wouldn't buy any you didn't need. Some guys will even trade shim for shim so both parties come out ahead. IF you buy them off e-bay for ex....just don't pay too much for them. I have seen guys pay more then you could get them from Z1 Ent. Personal preference but I decided to buy as needed and build over time.
- bountyhunter
- Thank you received: 337
02 Jan 2009 17:26 - 02 Jan 2009 17:29 #255814
by bountyhunter
Replied by bountyhunter on topic Shim kit, build or buy?
lx460 wrote:
Once the head is setup and broken in, you won't need many shims. I think I changed a shim maybe three times in about 50k miles on mine. I only bought two shims in all that time because on one I needed the size I had taken out so I didn't have to buy that one.
Last edit: 02 Jan 2009 17:29 by bountyhunter.
- bountyhunter
02 Jan 2009 17:28 #255815
by bountyhunter
lx460 wrote:
First get an accurate reading on each valve as to what shim is in there and what you need to get the clearance right. You may be able to swap some around to get as many right as possible. You may not need many shims when it's all said and done.
Any suggestions?
- OKC_Kent
- Thank you received: 20
02 Jan 2009 17:32 #255818
by OKC_Kent
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
Replied by OKC_Kent on topic Shim kit, build or buy?
What these guys said! My bike has needed two shims in 39,000 miles! And I traded them with the mechanic at the Kawi shop, so it's free.
Oklahoma City, OK
- lx460
02 Jan 2009 17:47 #255819
by lx460
2001 KZ1000P
1986 KZ1000P
1981 KZ1000LTD
1980 KZ1000
1988 KZ1000P
See a pattern?
Replied by lx460 on topic Shim kit, build or buy?
Here's the deal. I just picked up an 81 LTD with the J motor. It shows 22,000 on it. From the condition I'd say it's close. Pulled the valve cover and checked the valves. 5 of 8 I can't fit the smallest feeler gauge in (.051). Where do I go from here?
2001 KZ1000P
1986 KZ1000P
1981 KZ1000LTD
1980 KZ1000
1988 KZ1000P
See a pattern?
- Jeff.Saunders
02 Jan 2009 19:48 #255833
by Jeff.Saunders
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
Replied by Jeff.Saunders on topic Shim kit, build or buy?
If you can spin the bucket, you have some clearance - drop down two sizes in shim and you should be right there.
Even if the bucket will not spin, coming down 2 sizes is probably enough to get you acceptable clearance.
Shim kits - unless you have multiple bikes, individual shims are probably the best (cheapest) way to go. Most shim clearances shrink with wear causing progressively smaller shims to be used over time. The exception is where head work is done and new valves added - then you jump back up to thicker shims.
Z1 Ent on Facebook,
