piston i.d and tutorial????
  • trianglelaguna
  • trianglelaguna's Avatar Topic Author
31 Dec 2008 21:12
#255611
[img
so my bore kit is 71 mm and there is numbers on top of the pistons
4022ps
f38fo
xc
v :a direction arrow is where the v is ...there
is also a groove for getting at the wrist pin clip that is on the side instead of down like on the stock pistons...i am gonna try and post a picture of the top of the piston...i need help identifying the possible maker the guy i bought it from thought wiesco....also if you can tell a dummy how many cc's this pistonkit is goona be...i have a dammaged(bent) ring that i am gonna ask about later....thanks
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • trianglelaguna
Re: piston i.d and tutorial????
31 Dec 2008 21:19
#255612
[img
this is a top shot....any clues would be great.....could a guy get just one ring replaced for this piston?
i have the bad ring ...it was flatened on one end of the c and mangled a little...no other marks in the kit anywhere...i think if i can get a ring..and go from there??
thanks folks...
1976 KZ900
2003 ZX12R
2007 FZ1000
  • davel
  • davel's Avatar
31 Dec 2008 22:00 - 01 Jan 2009 08:37
#255618
4022ps
f38fo
xc
71mm Pistons from wiseco use 4022 in the part number. Should be wiseco. see www.wiseco.com for a catalog of pistons, rings, gaskets, etc.
CC = 1045
to calculate take (1/2 piston diameter squared) X (Pi) X (Stroke) X (# of cylinders) / 1000
So 1260.25 X 3.14 X 66 X 4 / 1000 = 1045
Last edit: 01 Jan 2009 08:37 by davel.
  • APE Jay
  • APE Jay's Avatar
31 Dec 2008 23:02
#255622
It is a Wiseco and takes an XC ring
  • CoreyClough
  • CoreyClough's Avatar
  • GPz550 Addiction
01 Jan 2009 06:53 - 01 Jan 2009 06:57
#255639
From Wiseco's Website Search for "Kawasaki" and "4022"
1045cc
2.795" or 71.00mm 1mm oversize for KZ1000 5mm oversize for KZ900 Stroke - 65.93mm
K1045 $593.46
10.25:1
Cylinder boring only
Piston: 4022M07100 $135.71
Rings: 2795XC
Piston Pins: S523
Retainer Clips: CW17 CFM20
Head Gasket: W3917 $54.95
Fiber Base Gasket: W5380 $14.04
Optional: Sleeve: KA627SL, 3099FA
I ren into this issue a while back on an engine of mine that came with "C" stamped on the crown of the piston. The "C" was for "XC" rings, but no one makes a set for my 615 Kit. The newer kits come with the XA rings and are thinner than the XC. Piston Groove is too large for the XA rings, so I would need new pistons, pins, and rings. E-Mail or call Wiseco and see if they still make the type of rings you need. Look at the Piston Ring section of Wiseco's Website, and measure your piston and rings to verify what they list.
Good Luck
'85 GPz550(ZX550-A2)
Last edit: 01 Jan 2009 06:57 by CoreyClough.
  • trianglelaguna
01 Jan 2009 07:11
#255642
thanks guy's these answers help me move forward.....into 09.....peace
1976 KZ900
2003 ZX12R
2007 FZ1000
  • APE Jay
  • APE Jay's Avatar
01 Jan 2009 10:57
#255664
I believe we have XCs in 71 mm
  • trianglelaguna
01 Jan 2009 12:06
#255674
well then...that it is great...let me look at my complete kit today and i will give a list to you of needs and my best attempts at a measure of anything(or should i go online at your site to order the items direct?)i believe i need some wristpin clips also...and maybe more...thanks a ton for the i.d too jay ...i'll respond and check responses later today.....peace
1976 KZ900
2003 ZX12R
2007 FZ1000
