changing cams
- Buda
30 Dec 2008 18:32 - 30 Dec 2008 18:53 #255450
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
changing cams was created by Buda
I got a set of standard J cams for my LTD and this is prob a silly ? but do I have to change the cam bearings.
They are $111 at Z1 a little more than I thought.
Thanks
Tom
Thanks
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Last edit: 30 Dec 2008 18:53 by Buda.
- PLUMMEN
- Thank you received: 104
30 Dec 2008 21:06 #255473
by PLUMMEN
Replied by PLUMMEN on topic changing cams
usually not if they arent banged up.
- BSKZ650
- Thank you received: 14
31 Dec 2008 05:57 #255500
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic changing cams
I dont think I have ever replaced a set of cam bearings on a bike,,,
- Buda
31 Dec 2008 08:22 #255519
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Replied by Buda on topic changing cams
Cool thanks fellas
Tom
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- gane
31 Dec 2008 18:16 #255598
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic changing cams
Tom, Here's one you dont' hear often, I don't know... On a whim I went to my KZ1000 micro-fiche, and it shows the bearings, and no size options. you might cross reference bearing PN's from your' 900 and the MK11, if they're the same,and cam journals mike out the same, youre' probly safe. the only way to know for sure, would be plasi-guage, , but that would mean removing valves.G
- keith1
- Thank you received: 2
31 Dec 2008 18:27 #255599
by keith1
Replied by keith1 on topic changing cams
when i went through my top end, mine where semi toasted in the middle of the bearing surface...bike had 30k on it and im not sure the maintenance history...i kind of looked at it from a car point of view.. if one section was clearly a different look from the rest of the bearing, why risk it?..
if the metal looks uniform all the way across the bearing surface, you should be set...mine werent...so i replaced them....keith
