'77 650 problems
- camostriker
30 Dec 2008 13:20 #255399
by camostriker
'77 650 problems was created by camostriker
hey guys. it's been a while since i have been on. finally got back to working on my bike after being in florida for four months. i am still having the same problems. it won't start. the battery is at full charge. the starter sounds good. the carbs have just been cleaned and synced. it just won't start for me. i have just over a week before i disappear to florida again. if i can't get it going before i leave i'm probably going to sell it cause i need to get riding, and eileen just won't go for me. does anyone have any ideas on what i need to do to make her go?
- OKC_Kent
- Thank you received: 20
30 Dec 2008 13:22 #255401
by OKC_Kent
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
Replied by OKC_Kent on topic '77 650 problems
The 77 uses points, are they set right and do you have spark? Timed?
How fresh is the gas? 4 months? Replace it.
Oklahoma City, OK
- Kawickrice
- Thank you received: 18
30 Dec 2008 13:32 #255403
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic '77 650 problems
My 650 was hard starting also for some reason. Check your points and make sure everything is good. You should also do the wiredgeorge coil mod to get strong spark. Mine had a trick, turn of headlight and kick it, sometimes it would start with ether and sometimes not. I think the electric start takes to much juice to fire if everything is not optimum. Mine also would not start under 65 degrees for some reason. Once running check your timing, carbs, voltage etc. Good luckB)
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- BSKZ650
- Thank you received: 14
31 Dec 2008 06:00 #255502
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic '77 650 problems
have you checked to see if you are getting spark at all.
at the very least ,,new points and condensers new plugs, and as said before,,,,new gas
