Quick advance cam question
- dman3998
28 Dec 2008 21:15 #255185
by dman3998
Dman
SE Idaho
"Smart only goes just so far, STUPID is UN-limited"
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
Quick advance cam question was created by dman3998
I need to remove the advance cam assembly but the bolt seems very tight in either direction. before I break it off, is it by chance a left hand thread?
Thanks
Thanks
Dman
SE Idaho
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
- MFolks
- Thank you received: 540
28 Dec 2008 21:54 #255188
by MFolks
Replied by MFolks on topic Quick advance cam question
It's the standard bolt type (turn to the right to tighten,left to loosen) Soak the bolt with PB blaster or similar penetrating oil followed by getting a block of wood and smacking the bolt with a hammer to break it loose.
Once you get it off use some silver anti-seize to make it easier to remove next time
- Sandy
- Fly High,Tony
- Thank you received: 13
28 Dec 2008 22:17 #255190
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic Quick advance cam question
You want to apply the torque to the smaller bolt,while you hold the other one with a wrench...13mm,and 17mm,if I'm not mistaken.It's been a while.
And yes,it probably IS corroded down in the threads.
And there are rubber parts on the advance mechanism,so don't depend on any serious heat to break it loose.
1977 KZ1000 A-1
- dman3998
28 Dec 2008 22:28 #255194
by dman3998
Dman
SE Idaho
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
Replied by dman3998 on topic Quick advance cam question
Thanks
Dman
SE Idaho
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
- bountyhunter
- Thank you received: 337
28 Dec 2008 22:29 #255196
by bountyhunter
Replied by bountyhunter on topic Quick advance cam question
Kroil is a super penetrant that will get under rust. The larger nut on mine is 17mm. I think you can put a 17mm box end on the larger nut and then put a socket on the little one.
