Valve adj. tools
- lx460
27 Dec 2008 20:03 #255013
by lx460
2001 KZ1000P
1986 KZ1000P
1981 KZ1000LTD
1980 KZ1000
1988 KZ1000P
See a pattern?
Valve adj. tools was created by lx460
From what I've read the kaw. factory tool (57001-110) seems to be prefered to the motion pro tool. But where do I get one? Between Myself, Dad, and my friend we have 5 kz1000 bikes (4 J models, 1 1980). I'm sure I'm not alone in neglecting the valve aspect of these engines. Time to get with the program. Anything that makes it easier will help. Any suggestions on where to get the factory tool?
2001 KZ1000P
1986 KZ1000P
1981 KZ1000LTD
1980 KZ1000
1988 KZ1000P
See a pattern?
- moneypit
- Thank you received: 35
27 Dec 2008 20:30 #255016
by moneypit
2-76 kz900
St Paul MN
Replied by moneypit on topic Valve adj. tools
Check Ebay. There's another post about this too and how to make your own. Check this post (I know there are easier ways: 1000 shims)
2-76 kz900
St Paul MN
- Beatpoet
27 Dec 2008 20:41 #255017
by Beatpoet
Replied by Beatpoet on topic Valve adj. tools
Here's one of my old posts - look on the bottom of the page for the (easy!) tools that I made with two sticks of high-carbon, a mapp torch, and a grinder.
kzrider.com/index.php?option=com_kunena&...imit=20&limitstart=0
- Sandy
- Fly High,Tony
- Thank you received: 13
27 Dec 2008 21:25 #255023
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic Valve adj. tools
1977 KZ1000 A-1
- trianglelaguna
- Thank you received: 235
27 Dec 2008 21:51 #255029
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic Valve adj. tools
now don't get inpatient with a guy..but... has anyone had any luck with the cheap knob lever and bat shaped combos you see on evilbay???...9.99-19.99 plus ship....do they suck...can it get me by for now till i want to shuck out 60-75 on the oem type?????i'm thinking i'll want to make one later when i'm playing with fabbing stuff but ...i should get the valve checking right.....SOON!!!!...peace craig
1976 KZ900
2003 ZX12R
2007 FZ1000
- Thank you received: 2098
27 Dec 2008 23:39 #255050
by Patton
Replied by Patton on topic Valve adj. tools
trianglelaguna wrote:
The batwing works fine, but not as quick and easy as the "factory" tool shown in Sandy's post.
Here's a prior thread with some helpful batwing info > Ask and ye shall receive
Z1E usually has these readily available, but at the moment shows temporarily out of stock. Here's the listing > Motion Pro batwing tool
Good Luck!
...has anyone had any luck with the cheap knob lever and bat shaped combos you see on evilbay....
Good Luck!
