kz 650 oil cooler swap
- Captaingamez
26 Dec 2008 22:10 #254818
by Captaingamez
1979 Kz1000 MKII road racer project
1994 Seca II, pile in the corner
1973 Honda cb175 cafe racer
1971 Yamaha AT1
1975 Massey Fergusson MF440
1971 Skiroule 300rr
kz 650 oil cooler swap was created by Captaingamez
i have a lockhart philips oil cooler setup made for a 1977-81 kz650 i was wondering if theres any easy way to adapt the included fitings to my 1979 kz1000 mkII
1971 Yamaha AT1
1971 Skiroule 300rr
- Mark Wing
- Thank you received: 22
26 Dec 2008 23:42 #254821
by Mark Wing
Yorba Linda Cal.
Replied by Mark Wing on topic kz 650 oil cooler swap
I don't think so, they have different oiling systems. That funny shaped oil diverter is the thought part to find on the 650's the other way is to use the GPZ 750 pan on a 650. On the 1000's the oil pick up is behind the jugs.
Mark
Mark
Yorba Linda Cal.
- Captaingamez
27 Dec 2008 09:16 #254905
by Captaingamez
1971 Yamaha AT1
1971 Skiroule 300rr
Replied by Captaingamez on topic kz 650 oil cooler swap
how do i hook up the oil cooler to the 1000 then. i see there are two caps. one on the pickup behind the cylinder and one on the right side of the crankcase in front of the clutch cover.
1971 Yamaha AT1
1971 Skiroule 300rr
- MFolks
- Thank you received: 540
27 Dec 2008 10:00 #254914
by MFolks
Replied by MFolks on topic kz 650 oil cooler swap
The 82 (and maybe 81) GPZ1100's have a oil cooler plumbed into the oil system below the injector bodies on the back of the engine. The website
www.earlsserviceshop.com
might have the parts that will work for you, if not try
www.oldkawman.com
as he will part out a bike now and then.
- pz1morton
01 Feb 2009 20:43 #261634
by pz1morton
1975 Z1 X 2 one i've had since new [many thanks to a great dad whos now since past]i've seen my son eyeing it every now and then.has 1075 kit,yosh cams,yosh pipe,29 smthbrs,rearsets.
1978 KZ650C that i race
1984 GPZ900
1972 CB350 building as another race bike
1982 CB750 w/836 kit,yosh cam
Replied by pz1morton on topic kz 650 oil cooler swap
I was told that a gpz550 oil pan would bolt on to a kz650 engine? that so any one know for sure?
Regards Paul
Regards Paul
1984 GPZ900
