I know there are easier ways: 1000 shims (cam out)
- pistolpete
The question is, as long as I play by the one cam out rule, keeping tension on at all times per the directions I read here earlier, what is stopping me from taking the cams out to swap out shims? I need to do 5 as it is, so I thought that using the tool would not save that much time anyway.
Thanks
And if you are in KC and want to swap shims before the new year, i am here for you!
- Mark Wing
- Thank you received: 22
Mark
Yorba Linda Cal.
- Thank you received: 2098
Good Luck!
- PLUMMEN
- Thank you received: 104
- trianglelaguna
- Thank you received: 235
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- PLUMMEN
- Kawickrice
- Thank you received: 18
im not close to where mine is but the wedge to hold the bucket down is just a piece of steel with an angle ground in it to fit between camshaft and edge of bucket,the pry tool is basically a heavy screwdriver with a hook bent at the right angle in the shank.heat up the shank of a reasonably short screwdriver with a heavy blade on it put a little bit of a bend in it then toss it in a bucket of oil,or a bucket of salt water to put some temper back into it.get a small diameter piece of stainless rod with points ground on each end with one end bent to a 90 degree angle and the other end straight to use for prying stubborn ones loose.magnet can be bought at any hardware store.what can i say,we're simple folks here in nebraska,coming from a long line of blacksmiths doesnt hurt either!:laugh:
Pic when you get a chance. Im not the metal worker either
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Tony
- Thank you received: 13
- PLUMMEN
- Tony
ya see im not the only hardheaded cheap bastard around here!Tony:your stock is rising!:laugh:
lol :laugh:
