kz 750 piston question
- RollingStock
24 Dec 2008 18:07 #254543
by RollingStock
73 z1900 street nitrous drag bike(powered but honda)
83 kz750 turbo street fighter project
kz 750 piston question was created by RollingStock
i plan on turboing my 83 kz750.. now my question is can i use the 810cc kit for a ZX750 E1 Turbo?
- APE Jay
- Banned
- Thank you received: 58
24 Dec 2008 21:40 #254574
by APE Jay
Replied by APE Jay on topic kz 750 piston question
Yes. You should be able to use the P809B kit.
Jay
Jay
- steell
25 Dec 2008 17:54 #254664
by steell
Replied by steell on topic kz 750 piston question
APE Jay wrote:
I may be wrong but I'm pretty sure the Turbo has larger wrist pins than the non Turbo, so you'd have to use the Turbo rods also (or ream out the stock ones).
Jay
- APE Jay
- Banned
- RollingStock
28 Dec 2008 19:21 #255155
by RollingStock
Replied by RollingStock on topic kz 750 piston question
crapers... anyone know where i can get a set of low comp pistons i can run on this motor without swaping rods or modding my stock ones?
only ones i can find ae high comp
- steell
28 Dec 2008 19:43 #255159
by steell
There are other ways to lower compression besides pistons.
Make the combustion chamber in the head larger by re-shaping it.
Put a spacer between the case and block.
Remove material from the top of the piston (Depending on pistons)
Get a set of pistons made by JE Pistons, if you're going to do that, then give serious thought to 880cc, they cost the same.
