cylinder head
- kz-mtd
cylinder head
21 Feb 2006 14:19
How much does the cylinder head have to do with overall power on stock or none stock motors?
- wireman
Re: cylinder head
21 Feb 2006 14:28
thats where it all starts everything comes in and goes out through the head,definately a big piece of the horsepower equation! :whistle:
- nitro3custom
Re: cylinder head
21 Feb 2006 14:32
A motor is really just an air pump. The more air you can pump through it the more you get out of it. A well designed cam, port optimised and better valving you get better flow.
- BohicaBob
- kz-mtd
- elseed
Re: cylinder head
23 Feb 2006 18:31
kz-mtd wrote:
All part of the whole... An improved head can't breathe better through low performance carbs. Can't breathe out through unimproved exhaust. Stock valve lift cams might not serve if everything changes around it. Etc.
Eventually you need 1428cc pistons or everyone laughs at you. Vicious circle.
How much does the carbs play apart in that?
'75 Z1B with mods
- savedrider
- 1975 Z1-B 900
Re: cylinder head
23 Feb 2006 19:33
elseed wrote:
Comon' elseed...you don't already have 1428cc pistons in your bike??? What's wrong with you???
kz-mtd wrote:How much does the carbs play apart in that?
Get right or get left! <*{{{><
