81 and 82 is there any difference
- Buda
20 Dec 2008 15:15
I bought a manual for a 81 KZ1000-1100 but i have a 82 KZ1000 is there anything that is different? I think they are mostly the same but i'm not sure.
Thanks
Tom
Thanks
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
10.25 to 1 comp
K&N pods
GPZ cams
- wiredgeorge
Re: 81 and 82 is there any difference
20 Dec 2008 15:58
Tom - Ain't any way to answer. There were surely small differences between the 81 and 82 KZ1000; The engine is essentially the same but there will be small differences in carburetor jetting and stuff like that. If you are looking to rebuild the engine, then you are likely fine. If you are looking at an 82 model that has different equipment than the 81 stuff, then like I said, there will be small differences. I think my bud Kano has a Haynes manual linked off our Vintage Motorcycle Tech forum linked off my website covering your model; you can double check most stuff although the Haynes is written in Brit English and is fairly incomprehensible as a result.
- Buda
20 Dec 2008 16:07
Thanks George its the factory kawasaki manual I bought it on ebay hopin it would be close.
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
10.25 to 1 comp
K&N pods
GPZ cams
- trianglelaguna
20 Dec 2008 16:57
i just got a 81 1000j standard and am starting to poke around at getting er going...i bought the same factory manual and it seems to cover both our bikes..and like george was saying pretty darn similiar.....far as i can tell the book covers changes and differences from the model years and models...peace
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
20 Dec 2008 22:15
The only differences that I can recall at the moment (it's late, so keep that in mind) are that in '82 the clutch release mechanism was greatly simplified and the starter went from 2 to 4 brushes.
