Clutch Hub Removal- HELP!!
- TLH101
21 Feb 2006 12:33 #25372
by TLH101
Clutch Hub Removal- HELP!! was created by TLH101
OK, I have my engine out of the bike, maybe a little prematurely. How can I hold the clutch hub to get the nut loose. I see where I could have used the chain and brakes if the motor was still in the bike, but what do I do now?
- wireman
- Visitor
21 Feb 2006 12:37 #25374
by wireman
Replied by wireman on topic Clutch Hub Removal- HELP!!
take an old steel clutch plate and weld a handle on to it.goodluck,happy wrenching!
- TLH101
21 Feb 2006 13:16 #25384
by TLH101
Replied by TLH101 on topic Clutch Hub Removal- HELP!!
Well, I got ahead of myself. Seems a liitle bit of thought and I figured it out. I had a 1/2" impact, so I was able to reinstall all the clutch plates. Then by just pushing on them with one hand, I was able to create enough friction to release the nut, with the impact wrench. Too simple.:woohoo:
- wireman
- Visitor
21 Feb 2006 13:51 #25394
by wireman
make the clutch plate tool it will make it easier when you go to torque it down when you put it back together:whistle: goodluck,happy wrenching!
