ENGINE SWAP
- steell
20 Dec 2008 18:06 #253744
by steell
Replied by steell on topic ENGINE SWAP
wiredgeorge wrote:
Yeah, something that was designed to handle the torque of the bigger motor. A frame that wouldn't crack at the welds or get twisted like limp spaghetti over time.
The rear brake looks like a disk. What is that thing that looks like a tin can with three holes? Why not just use a 900/1000 frame and have the engine bolt right up?
- Bluemeanie
- Thank you received: 14
21 Dec 2008 05:55 #253824
by Bluemeanie
Replied by Bluemeanie on topic ENGINE SWAP
Are people trying to do the V8 Vega, V8 Pinto engine swap thing? Big engine, little car? My 650 weighs 465lbs dry, what does a 900/1000 weigh? Is it about better handling with the 650 frame? With all the work done (assuming frame bracing, etc), what advantages are you going to end up with?
- Old Man Rock
- Thank you received: 225
21 Dec 2008 06:52 #253838
by Old Man Rock
Faster way to die....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic ENGINE SWAP
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
